SMTP Client
  • maxijose
    • May 2007
    • 36
    SMTP Client
    To take advantage of the email notification functionality, I think we need an SMTP client of course.
    What should I get exactly?
    Thanks.
  • Alexei
    Founder, CEO
    • Sep 2004
    • 5654
    What you need is a SMTP server to deliver messages generated by ZABBIX.
    Alexei Vladishev
    New York | Tokyo | Riga
    My Twitter
    • NOB
      • Mar 2007
      • 469
      Thanks.
      No client.
      Just do the configuration in the Web frontend -> Adminstration / Media Types / Email
      and enter the data for the fields
      SMTP Server - your internal SMTP server used for sending E-Mails to external receivers,
      SMPT helo - an identification of your server, e.g., the hostname, and
      SMTP Email - will show up as the sender of the mail.
      That's all.
      HTH,
      Norbert.
      • maxijose
        • May 2007
        • 36
        Thanks, it's working now.
        It was a simple DNS problem on my network, I'm sorry for the inconvenience.
        • javierin79
          • Aug 2007
          Hi.
          I bet i'm being a bit clumsy again but the only place i seem to find email as an option is under Configuration, users media type and there's no server configuration there.
          I'm running 1.4.2
          • javierin79
            • Aug 2007
            Ok i found it...
            Just in the case someone doesn't find it at a glace, as It happened to me, There's a drop down menu at the very right of the Configuration, General screen
