Zabbix is not use syslog!
  • Filter
    Hello, i am a french user of zabbix,
    I am using zabbix 1.0 release, because i am in a production envirronement
    first : thanks for your jobs, zabbix is a great monitoring tool.
    second :I have some problems :
    although in the configuration files of zabbix_suckerd and zabbix_agentd, i'm not use the "LogFile" parameter, zabbix is not using syslog.
    In syslog.conf i have write :
    "*.* /var/log/allmessages"
    and i create this files, and reload syslog
    but there's no trace of zabbix in /var/log/allmessages
    of course i can use the logfile but in this way, i can't export the log to another server.
    until i resolv this problem i am using the logfile.
    if anyone know how to resolve my probleme?
    thank you in advance
    i've never used the syslog daemon to log messages from Zabbix, i've always used the log files that Zabbix generates on it's own.
    I'm not sure, but i think you can push messages to the syslog daemon, but unfortunately i don't know how exactly.
    Perhaps someone else can throw some light on this.
      thank you for your answer
        Is anyone use syslogd instead of the log file?
          I have exactly the same problem. Not setting LogFile or setting it to nothing ("LogFile=") deactivates logging, nothing ever reaches syslog. I'm using Zabbix 1.4 and syslog-ng 1.6.11 on Gentoo. Is this a bug or am I doing something wrong?
          Bye,
          Kevin
            Bye,
            Kevin
            Try this:
            /usr/bin/logger -p local0.err -t zabbix -u /var/log/zabbix-server/zabbix-server.log
            See if zabbix can log into socket instead of log file (probably log rotation should be turned off & logfile deleted).
              Thanks for reporting this problem.
              Alexei Vladishev
              New York | Tokyo | Riga
              My Twitter
                also the same issue in 1.6. any news about that ?
                  Patch
                  --- src/libs/zbxlog/log.c.orig 2010-01-29 15:49:19.000000000 +0300
                  +++ src/libs/zbxlog/log.c 2010-01-29 15:49:33.000000000 +0300
                  @@ -109,7 +109,6 @@
                  #else /* not _WINDOWS */
                  openlog("zabbix_suckerd", LOG_PID, LOG_USER);
                  - setlogmask(LOG_UPTO(LOG_WARNING));
                  #endif /* _WINDOWS */
                  Announcement
                  No announcement yet.
