Graphs showing wrong values...
  • AdrianS
    • Mar 2007
    • 12
    I'v notice a strange problem with graphs (1.4.1) - when showing more then few days (only with some graphs), shown data are completely inaccurate. When I choose to show last values of specific period - everything is ok.
    Here is an example
    This is OK 3 days graph
    This is wrong 4 days graph (should be like before till 20 July ~4TB and after 6TB)
    And here are values for period of last graph (4 days)
    Any idea what can be wrong - is this bug known already?
    Regards
    Adrian (Sauron) Siemieniak /,/ .. Who can destroy The Thing,
    sauron{at}rpg{dot}pl /`/ controls The Thing ... (DUNE)
  • Alexei
    Founder, CEO
    • Sep 2004
    • 5654
    Thanks for reporting this. This is more serious problem than it looks. Basically it is related to a limited precision of values stored in the table 'trends'. It will be fixed in 1.6. Unfortunately it cannot be fixed in 1.4.x because database patching is required.
    Alexei Vladishev
    New York | Tokyo | Riga
    My Twitter
    • AdrianS
      • Mar 2007
      • 12
      So it is enough to do
      ALTER TABLE `trends` CHANGE `value_min` `value_min` DOUBLE( 18, 4 ) NOT NULL DEFAULT '0.0000';
      ALTER TABLE `trends` CHANGE `value_avg` `value_avg` DOUBLE( 18, 4 ) NOT NULL DEFAULT '0.0000';
      ALTER TABLE `trends` CHANGE `value_max` `value_max` DOUBLE( 18, 4 ) NOT NULL DEFAULT '0.0000';
      and erase/change wrong data in "trends" table? Or there is also some limitation in aggregating formula in zabbix?
      ps. value 18,4 is just for example - for this case should be enough
      • AdrianS
        • Mar 2007
        • 12
        Ok I'v checked and it's working - in this case it was easy to fix all data in trends (for this itemid) , because there was only one change of it in entire history .
        I think it should be fixed before 1.6, since leaving it this way, simply can corrupts data - which can't be fixed later. This simple sql query (to change double precision) took on my trends table (about 5426605 values) less then a minute.
        • Alexei
          Founder, CEO
          • Sep 2004
          • 5654
          I'm thinking of adding an extra table into 1.6, trends_uint for keeping trends of 64 bit unsigned integer data.
          Alexei Vladishev
          My Twitter
