Host status not updating.
  • deceased
    • Sep 2007
    I have issues with zabbix item "status". I had 1.4.2 installed on debian, then upgraded to test version 1.4.3, but host status is not working. Actualy it stopped working on 1.4.1.
    When i do manual query with zabbix_get i get this :
    heseos:~# zabbix_get -s10.69.23.230 -p10050 -k"status"
    ZBX_NOTSUPPORTED
    heseos:~# zabbix_get -s10.69.23.230 -p10050 -k"agent.ping"
    1
    heseos:~# zabbix_get -s10.69.23.230 -p10050 -k"agent.version"
    1.4.2
    heseos:~#
    Anyone has an idea ?
  • bbrendon
    • Sep 2005
    • 873
    I'm not sure how many people actually use host status. I'd be curious to hear ... I know status exists, but I never understood the point. Maybe its something zabbix uses internally or the documentation has something about it.
    I think your best bet to determine if a host is down is use agent.ping (or any other item) item with a nodata trigger.
    Unofficial Zabbix Expert
    Blog, Corporate Site
    • Alexei
      Founder, CEO
      • Sep 2004
      • 5654
      You are right. The host status has limited use and is actually useless in case if active checks are only used.
      Alexei Vladishev
      New York | Tokyo | Riga
      My Twitter
      • bbrendon
        • Sep 2005
        • 873
        Yay! Point for me
        • deceased
          • Sep 2007
          Hmm, but
          {Template_Windows:agent.ping.last(0)}#1&{Template_ Windows:agent.ping.nodata(120)}=1
          Never triggers
          • Alexei
            Founder, CEO
            • Sep 2004
            • 5654
            Originally posted by deceased
            Hmm, but
            Never triggers
            ZABBIX works absolutely right. The agent.ping ALWAYS returns 1, read the manual.
            Alexei Vladishev
            My Twitter
            • deceased
              • Sep 2007
              Ok, I allready figured it out, just didn't write it here
              Sorry for bothering
              • mcortinas
                • Oct 2011
                Status seems "deprecated"??
                In Red Hat infraestructure status seems "deprecated"??
                # /opt/zabbix/sbin/zabbix_agentd --version
                Zabbix Agent (daemon) v1.8.7 (revision 21394) (1 September 2011)
                Compilation time: Sep 28 2011 18:05:06
                # /opt/zabbix/bin/zabbix_get -s62.73.191.162 -p10050 -k"status"
                ZBX_NOTSUPPORTED
                # /opt/zabbix/bin/zabbix_get -s62.73.191.162 -p10050 -k system.hostname
                evl0600093
                Marc
                • pswen
                  • May 2011
                  Any idears ?
                  if not get value , how to known client was down.
