Remove zabbix agentd from event log
  • lunix
    • Jul 2006
    Zabbix agent is filling my event log with tons of data(circular logging) and that is not desired because i loose the rest of the log(i don't have any log aggregator running).
    i can't find a way to disable this behaviour. Been through the foruns, wiki and manual.
    there used to be a way to disable this with the remove-events option on the agent, but it does not work with zabbix_agentd.exe version 1.4.2 (downloaded from the site).
    can anyone point out the procedure?
  • lunix
    • Jul 2006
    some light
    found this:
    minimizes the problem
    i'll try it and report...
