Auto discovery problems
  • testos
    • Apr 2007
    • 85
    Setting DebugLevel=4 in zabbix_server.conf and activating any discovery rule, zabbix server is stopped:
    PHP Code:
    11581:20071126:144919 Query [select druleid,iprange,delay,nextcheck,name,status from drules where status=0 and nextcheck<=1196084959 and mod(druleid,1)=0 and druleid>=100000000000000*0 and druleid<=(100000000000000*0+99999999999999) ]
    11581:20071126:144919 In process_rule(name:Local,range:10.12.127.65)
    11535:20071126:144919 One child process died. Exiting ...
    11540:20071126:144919 Got signal. Exiting ...
    11538:20071126:144919 Got signal. Exiting ...
    11546:20071126:144919 Got signal. Exiting ...
    11545:20071126:144919 Got signal. Exiting ...
    11539:20071126:144919 Got signal. Exiting ...
    11563:20071126:144919 Got signal. Exiting ...
    11562:20071126:144919 Got signal. Exiting ...
    11542:20071126:144919 Got signal. Exiting ...
    11543:20071126:144919 Got signal. Exiting ...
    11551:20071126:144919 Got signal. Exiting ...
    11559:20071126:144919 Got signal. Exiting ...
    11567:20071126:144919 Got signal. Exiting ...
    11570:20071126:144919 Got signal. Exiting ...
    11577:20071126:144919 Got signal. Exiting ...
    11554:20071126:144919 Got signal. Exiting ...
    11572:20071126:144919 Got signal. Exiting ...
    11556:20071126:144919 Got signal. Exiting ...
    11579:20071126:144919 Got signal. Exiting ...
    11575:20071126:144919 Got signal. Exiting ...
    11550:20071126:144919 Got signal. Exiting ...
    11574:20071126:144919 Got signal. Exiting ...
    11535:20071126:144921 ZABBIX Server stopped
    Setting DebugLevel=3 in zabbix_server.conf and activating any discovery rule (even simple rules), zabbix server remain up but autodiscovery don't work. Why ????
  • testos
    • Apr 2007
    • 85
    Does anyone have reproduced this problem?
    Thanks.
    • Niels
      • May 2007
      • 239
      Are you saying that a discovery rule crashes the server with debuglevel=4, but not with debuglevel=3? If so, that's obviously a serious bug you should report.
      Which version are you using?
