HP-UX ia64
  • enuke
    • Mar 2008
    HP-UX ia64
    Hi
    I have problem with monitoring network interface in hpux 11.23.
    I have lan0, lan1 but hp-ux template in zabbix agent for hpux11.23 is eth0 eth1
    and this item is "Not supported by ZABBIX agent"
    pleass help
    thanks for ideas
  • hml
    • Apr 2008
    HP-UX lan
    Just wondering if you had any news on your post. I have managed to make it
    work under Solaris by cloning the items incoming/outgoing traffic on eth0.
    Then you can replace the NIC name to the one that the system uses and the status changes to Active.
    However the same approach has not helped on HP-UX (PA-RISC or IA64)
    • aic
      • Oct 2010
      • 50
      Hi All,
      Is there any news about this topic?
      I will need to monitor lan1 and Zbx can't do it yet
      Thanks!!
      • marcel
        • Oct 2010
        • 112
        zabbix agent does not support mionitoring of LAN interfaces on HPUX
        try this as user parameter - you can put it ito a shell script (ksh):
        parameter 1 is either net.packets.in or net.packets.out and parameter two is the name of the interface
        #!/bin/ksh
        case $1 in
          net.packets.in)
            raw=`netstat -in | grep -e "^$2 " | awk '{print $5}'`
            echo $raw
          net.packets.out)
            raw=`netstat -in | grep -e "^$2 " | awk '{print $7}'`
            echo $raw
        esac
        Zabbix Certified Specialist for Large Environments since 12/2010
        • aic
          • Oct 2010
          • 50
          I will do. Thank you very much.
          • suhailsid
            • Oct 2019
            Please help me to.monitor hpux network interface on ia64 hpux 11.31 its visible in zabbix with correct name lan900 but showing not supported :-(
