Updated Jan 8, 2010: Fixed all problems everyone has complained about here, and in my blog. In summary: Added zabbix-proxy support, fixed 64-bit missing repodata, fixed file permissions, fixed problem with upgrading the package (thanks Tim!) added curl support (web scenarios work now, yay!).
Hey guys!
I built a spec file and RPMs for Zabbix 1.8 for CentOS and I'm hosting a repository for them for anyone to use. This might simplify some people's installation, especially on tons of servers (I manage lots of servers, installing anything via anything except RPMs is not scalable).
For instructions on how to perform this install, simply add my repository, and then install yum install zabbix-agent (or server).
Details are here: http://andrewfarley.com/sysadmin/rpm-repository-online
NOTE: If you have problems installing zabbix-web, please visit: http://www.zabbix.com/forum/showpost...36&postcount=7
Your feedback and input is welcome. And any recommended changes to my specfile are welcome also, preferably in the form of a patch, but if you're not a nerd just let me know and I can revise it.
Cheers!
Hey guys!
Cheers!
Should just have to yum update and then yum upgrade and grab the latest revision of the package to fix this up for you!
