Orabbix:"Another way to monitor Oracle reloaded"
Andrea Dalle Vacche
website:http://www.smartmarmot.com/
e-mail:
Author of:Mastering Zabbix Book - second edition
Zabbix Network Monitoring Essentials -
Your support is great thank youbest guess is, are you running in archivelog mode?
if no, then it won't show up because of the RaceCondition.
if yes, put the query in sqlplus, first as sysdba if that works, try it on the orabbix user.
if it's still working, try the RaceConditionQuery in sqlplus.
if everything seems ok to you, then be sure to run orabbix 1.2rc2.
otherwise i'm lost
FelixAndrea Dalle Vacche
e-mail:
Zabbix Network Monitoring EssentialsComment
Code:sqlplus "zabbix/pass" SQL*Plus: Release 9.2.0.7.0 - Production on Tue Apr 26 16:39:29 2011 Copyright (c) 1982, 2002, Oracle Corporation. All rights reserved. Connected to: Oracle9i Enterprise Edition Release 9.2.0.7.0 - Production With the Partitioning, OLAP and Oracle Data Mining options JServer Release 9.2.0.7.0 - Production SQL> select log_mode from v$database; LOG_MODE ------------ ARCHIVELOG SQL> select round(A.LOGS*B.AVG/1024/1024/10) from ( SELECT COUNT (*) LOGS FROM V$LOG_HISTORY WHERE FIRST_TIME >= (sysdate -10/60/24)) A, ( SELECT Avg(BYTES) AVG, Count(1), Max(BYTES) Max_Bytes, Min(BYTES) Min_Bytes FROM v$log) B; ROUND(A.LOGS*B.AVG/1024/1024/10) -------------------------------- 0 SQL> select value from v$parameter where name='log_archive_start'; VALUE -------------------------------------------------------------------------------- TRUE SQL>Comment
If all your database are in archivelogmode you can remove the racecondition simply removing from query.props- archive.RaceConditionQuery
- archive.RaceConditionValue
Or you can have one query file for each of your database or better to have a cutom queryfile for some particular database
adding in config.props
<DBNAME>.QueryListFile=<path to your custom queryfile>
e.g.
DBTEST.QueryListFile=./conf/queryfortest.props
Or if you want one queryfile for all database that are in archivelogmode or aren't in archivelogmode you can add a race condition
e.g.
archive.RaceConditionQuery=select value from v$parameter where name='log_archive_start'
archive.RaceConditionValue=TRUE
let me know if you still have issueAndrea Dalle Vacche
e-mail:
right, seems ok to me
you can try to disable the RaceConditionValue and RaceConditionQuery
like
#archive.RaceConditionValue={somevalue}
#archive.RaceConditionQuery={somequery}
and check if that gives you a value (need to wait a few minutes after changing it)
and check the item in zabbix, it could be disabled.Comment
I've stopped orabbix, changed
archive.RaceConditionValue=FALSE
to
started orabbix
and Archivelog counter appeared in zabbix
then I stopped orabbix, changed
to
started orabbix
and Archivelog counter stayed in zabbix
I will watch after this counter if it receive any updates.
dalle, fflux thanks for excellent support!Comment
if you change a parameter in query file you don't need restart Orabbix, query are refreshed dynamically every 5 minute.I've stopped orabbix, changed
to
started orabbix
to
started orabbix
Please try to check the timestamp of the last received item,because it is possible that in Graphics do not see the "hole" and maybe that the last received item it's quite old.
Zabbix need a little to show the "hole" in graphs.Andrea Dalle Vacche
e-mail:
Andrea Dalle Vacche
e-mail:
First I want to thank you for developing this great tool!
I want to monitor the folowing items and was wondering if this is already in the default trigger/item template:
1. Instance is up. (alive item?)
2. Listener is up. (alive item?)
3. Backup errors. (?)
4. Tablespaces. (tbl_space item)
5. Dead locks. (locks item?)
6. Archiver errors (?)
7. Alert log errors (There is an ALERT_LOG item but what does it do?)
Also I was wondering if there is some more documentation about the default items/triggers and there meanings?
Thanks in advance!Comment
oi thats a lot of questionsFirst I want to thank you for developing this great tool!
Thanks in advance!
1: yes
2: no but thats not needed, as orabbix uses the listener, so no listeren is an error
3: no, see below
4: yes
5: yes oracle 10+
6: no see below
7: no see below
3a: we changed our backup scripts to use zabbix_send to update the status of the backup
and i made a orabbix (oracle) query to check if there was a backup in the last 25 hours
6/7 Archive error is just an oracle error, oracle 11 has a table that lists the oracle errors, so i made a query to count the errors in the last hour and put a trigger on > 0
my last comment,
just use it and play with it, you can do a lot, the possibility is only hindered by your imagination
Thanks for you quick reply!
I will check the error and backup tables!
Edit:
This is what I'm going to use.
1. Monitoring the status of the last backup
select status from V$RMAN_BACKUP_JOB_DETAILS
where end_time = (select max( end_time) from V$RMAN_BACKUP_JOB_DETAILS)
2. Monitoring the age in days of the last backup
select round(sysdate - end_time) from V$RMAN_BACKUP_JOB_DETAILS
3. Checking the overall status of the database
status, archiver, logins, shutdown_pending, database_status, active_state, blocked fields in V$INSTANCE
This and the default triggers will hopely cover the most important part of oracle
this is what i use, mind you i use oracle 11 for this
1:
rman_backupdone.Period=60
rman_backupdone.Query=select to_char(end_time,'DD/MM hh24:mi ') from sys.v_$rman_status where start_time > (sysdate -1 - 1/24) and object_type='DB FULL' and operation='BACKUP' order by end_time DESC
rman_backupdone.NoDataFound=none
for the next check you need to create a view with the username you use for orabbix:
CREATE VIEW v_x$dbgalertext AS SELECT * FROM x$dbgalertext;
GRANT select ON SYS.v_x$dbgalertext TO "{orabbixdbuser}";
ora_error.Period=60
ora_error.Query=select count (*) from sys.v_x$dbgalertext where originating_timestamp > (sysdate - 60/1440) and message_text like '%ORA-%'Comment
Thanks for that query I will use this by our Oracle 11G instances. (Only works with 10 and up).for the next check you need to create a view with the username you use for orabbix:
ora_error.Period=60
Also another question. The trigger 'hitratio' triggers every few minutes with the status 'Unknown'. I'v checked the four items related to this trigger but they all have values.
Anyone any idea what is going wrong?
