Orabbix:"Another way to monitor Oracle reloaded"
  • mxa
    • Feb 2009
    • 12
    #286
    Problem with AIX 5.3
    On project page, there is mentioned, that orabbix was tested with AIX 5.3, I try with 1.2.0 rc3
    when I run run.sh I get wrong java version.
    # ./run.sh
    # The java class could not be loaded. java.lang.UnsupportedClassVersionError: com/smartmarmot/orabbix/bootstrap (Unsupported major.minor version 50.0)
    Our java version:
    # java -version
    java version "1.4.2"
    Java(TM) 2 Runtime Environment, Standard Edition (build 1.4.2)
    Classic VM (build 1.4.2, J2RE 1.4.2 IBM AIX build ca142-20090307 (SR13) (JIT enabled: jitc))
    I am aware that it should be 1.6 not 1.4, but as far as I know 1.4.2 is already a newest java version that is available..
    So I will probably need some jar created in 1.4 not in 1.6.. Do someone have some experience? I don't want to be force try older versions.. at this point I don't know what else can I do..
    I won't be able install sun java, at this point I'm working on test environment, but on production there will no possibility to change any existing part of IT environment.. so..
    BTW: I tried to (multiple times) send info in contact us in http://www.smartmarmot.com/about/#FSContact1 but every time there is an error with CAPTCHA Code -this is also my try to inform author that there is a problem..
    Could not read CAPTCHA token file. Try again.
    PS: Orabbix tested on OEL -works great..
    So i will propably need some jar created in 1.4 not in 1.6.. Do someone have some experience? I don't wath to be force to try older versions..
    • dalle
      • Mar 2009
      • 402
      #287
      # ./run.sh
      Our java version:
      # java -version
      I'm sorry for your issue with CAPTCHA I'm going to check if is readabale thank you to notice it to me!
      mmm
      If you can't install java sun 1.6 it's not so easy....
      I can try to compile it with the old one (1.4) but I'm not sure that is possible let me try.
      Andrea Dalle Vacche
      website:http://www.smartmarmot.com/
      e-mail:
      Author of:Mastering Zabbix Book - second edition
      Zabbix Network Monitoring Essentials
      • mxa
        • Feb 2009
        • 12
        #288
        Originally posted by dalle
        mmm
        I would be very very thankful, really..
        If it works, I may be able to help you in conversion from Linux version of script to AIX when I'm done If you interested (it's silly thing like for loop with echo -n that does not exist in AIX so run.sh fails.. that kind of stuff)
        Maybe some of your users will be interested in AIX version
        • kawakamikun
          • Jul 2011
          Zabbix Agent
          iam new here and i try to configure the orabbix.
          1 question- i need to install zabbix agent on host that contain the oracle?
          how to create the host on zabbix? with the oracle address or zabbix address?
          • fflux
            • Mar 2011
            • 34
            #290
            You need to install orabbix on the zabbix server.
            you need to create a host to define the database in zabbix, we use hostname-dbname (but you can do what you want)
            and the dns-name would be the name of the server the oracle database runs on.
            and assign the orabbix template to it.
            the first part in config.props is the name you give the database in zabbix.
            • kawakamikun
              • Jul 2011
              I configure how u explain, the triggers is OK, but the graphs dont work.
              The logs inform that the connection with database is succefull.
              My Oracle Server is hosted in outside datacenter.
              • mxa
                • Feb 2009
                • 12
                #292
                Problem with AIX 5.3 -CD
                I was wrong to IBM java 1.4.2
                I found on that Java 6 =1.6.
                now while ececuting run.sh (upgraded -original run.sh is for Linux, not AIX)
                /usr/java6_64/bin/java -Duser.language=en -Duser.country=US -Dlog4j.configuration=/opt/orabbix/conf/log4j.properties -cp /opt/orabbix/lib/commons-codec-1.4.jar:/opt/orabbix/lib/commons-dbcp-1.4.jar:/opt/orabbix/lib/commons-lang-2.5.jar:/opt/orabbix/lib/commons-logging-1.1.1.jar:/opt/orabbix/lib/commons-pool-1.5.4.jar:./orabbix-1.2.0-RC3.jar com.smartmarmot.orabbix.bootstrap start /opt/orabbix/conf/config.props &
                I get:
                # Exception in thread "main" java.lang.NoClassDefFoundError: org.apache.log4j.Level
                at com.smartmarmot.orabbix.Orabbixmon.<init>(Orabbixm on.java:46)
                at com.smartmarmot.orabbix.bootstrap.main(bootstrap.j ava:52)
                Caused by: java.lang.ClassNotFoundException: org.apache.log4j.Level
                at java.net.URLClassLoader.findClass(URLClassLoader.j ava:434)
                at java.lang.ClassLoader.loadClass(ClassLoader.java:6 60)
                at sun.misc.Launcher$AppClassLoader.loadClass(Launche r.java:358)
                at java.lang.ClassLoader.loadClass(ClassLoader.java:6 26)
                ... 2 more
                There is no log created
                if I try:
                /usr/java6_64/bin/java -Duser.language=en -Duser.country=US -Dlog4j.configuration=./conf/log4j.properties -cp /opt/orabbix/lib/commons-codec-1.4.jar:/opt/orabbix/lib/commons-dbcp-1.4.jar:/opt/orabbix/lib/commons-lang-2.5.jar:/opt/orabbix/lib/commons-logging-1.1.1.jar:/opt/orabbix/lib/commons-pool-1.5.4.jar:./orabbix-1.2.0-RC3.jar com.smartmarmot.orabbix.bootstrap start ./conf/config.props &
                # pwd
                /opt/orabbix
                # ix-1.2.0-RC3.jar com.smartmarmot.orabbix.bootstrap start ./conf/config.props & <
                [1] 262292
                ... 2 more
                The is pid file created.. but still that all..
                • mxa
                  • Feb 2009
                  • 12
                  #293
                  ok, I did try copy line from ps wfom my test OEL where I have working orabbix (whats funny on OEL it took me 1h, on AIX like 10h.. and it's still not working)
                  Now I got:
                  # /usr/java6_64/bin/java -Duser.language=en -Duser.country=US -Dlog4j.configuration=./conf/log4j.properties -cp lib/commons-codec-1.4.jar:lib/commons-dbcp-1.4.jar:lib/commons-lang-2.5.jar:lib/commons-logging-1.1.1.jar:lib/commons-pool-1.5.4.jar:lib/log4j-1.2.15.jar:lib/ojdbc6.jar:.:./orabbix-1.2.0-RC3.jar com.smartmarmot.orabbix.bootstrap start ./conf/config.props
                  Stopping
                  java.lang.Exception: ERROR on main - Connections is empty
                  at com.smartmarmot.orabbix.Orabbixmon.run(Orabbixmon. java:101)
                  at com.smartmarmot.orabbix.bootstrap.main(bootstrap.j ava:54)
                  So it look much better
                  At this momnet its really nothing listening on 1521, my SID is ok.. I will have to check with someone from Orcale team, but I'm much more optimistic..
                  • Keitamax
                    • Jun 2011
                    • 19
                    #294
                    thank you for your work! I managed to monitor an Oracle server, works great, except for some parameters : i get no data for DBSize, DBFilesSize and the numerous eventwaits stats.
                    In Orabbix.log:
                    2011-07-21 08:50:19,719 [pool-1-thread-16] WARN Orabbix - Error while executing ->dbversion- on database ->My_DB- Exception received ORA-02003: invalid USERENV parameter
                    2011-07-21 08:50:19,719 [pool-1-thread-16] ERROR Orabbix - Error on DBEnquiry on query=dbversion on database=My_DB Error returned is java.lang.IllegalArgumentException: null value for key 'dbversion'
                    Would you have a clue what's going wrong?
                    • dalle
                      • Mar 2009
                      • 402
                      #295
                      Now I got:
                      Stopping
                      To solve this issue you need your Oracle Up and running at least one server... otherwise Orabbix can't create his own internal structure.
                      let me know when you have one Oracle server running
                      Andrea Dalle Vacche
                      e-mail:
                      • dalle
                        • Mar 2009
                        • 402
                        #296
                        In Orabbix.log:
                        what version of oracle are you using?
                        I will try to reproduce your issue this one seem a trouble made by jdbc session.
                        Andrea Dalle Vacche
                        e-mail:
                        • Keitamax
                          • Jun 2011
                          • 19
                          #297
                          Here it is :
                          Oracle9i Enterprise Edition Release 9.2.0.8.0 - Production
                          PL/SQL Release 9.2.0.8.0 - Production
                          CORE 9.2.0.8.0 Production
                          • mxa
                            • Feb 2009
                            • 12
                            #298
                            Aix 5.3 ok
                            It wasn't any problem from this point.
                            Oracle instance was running, but, as I said, 1521 wasnt listening, (It was test enviroment.. and listener was stopped)
                            lsnrctl start
                            and problem solved
                            Thank you for produkct and support Adrea
                            • dalle
                              • Mar 2009
                              • 402
                              #299
                              lsnrctl start
                              and problem solved
                              opppsss sorry I didn't read right ...
                              Andrea Dalle Vacche
                              e-mail:
                              • dalle
                                • Mar 2009
                                • 402
                                #300
                                Here it is :
                                mmm right... on 9i don't work this kind of query...
                                I don't have any more Oracle 9i here to make some test but i think that you can change your query so:
                                dbversion.Query=select * from v$version where banner like 'Oracle%'
                                dbversion.Period=720
                                I know that is "restrictive" but this should work right
                                Andrea Dalle Vacche
                                e-mail:
