agent.ping with nodata false triggers
  • bashman
    • Dec 2009
    • 432
    When I use this trigger:
    {HOSTNAME:agent.ping.last(0)}=0 | {HOSTNAME:agent.ping.nodata(300)}=1
    with this item:
    Type ZABBIX agent
    Key agent.ping
    It false triggers for some hosts.
    978 Hosts / 16.901 Items / 8.703 Triggers / 44 usr / 90,59 nvps / v1.8.15
  • bbrendon
    • Sep 2005
    • 873
    It seems like you're duplicating checks. Why not just pick one method to determine if an agent is down and then troubleshoot from there?
    Unofficial Zabbix Expert
    Blog, Corporate Site
    • bashman
      • Dec 2009
      • 432
      I did, but the nodata still false triggers.
      I want to know when a host is dead, and the agent.ping.last doesn't alert me when a host is dead, that's why I want the nodata function.
      Thanks for your response.
      • MrKen
        • Oct 2008
        • 652
        In this post, Elvar says he fixed this problem by increasing the timeout in the zabbix_server.conf
        HTH
        • bashman
          • Dec 2009
          • 432
          Hi Mrken,
          I fixed my problem thanks to your post: http://www.zabbix.com/forum/showthre...6362#post56362
          I checked if the hostname in the zabbix_agentd.conf was the same in the zabbix gui and It wasn't for the host that false triggered.
          Thank you very much.
          • bashman
            • Dec 2009
            • 432
            After a while the problem still remains, the zabbix_agentd log entry:
            20683:20091229:104541 zabbix_agentd started. ZABBIX 1.6.6 (revision 7836).
            20684:20091229:104541 zabbix_agentd collector started
            20686:20091229:104541 zabbix_agentd listener started
            20685:20091229:104541 zabbix_agentd listener started
            20687:20091229:104541 zabbix_agentd listener started
            20688:20091229:104541 zabbix_agentd listener started
            20689:20091229:104541 zabbix_agentd listener started
            20690:20091229:104541 zabbix_agentd active check started [<IP>:10051]
            20686:20091229:113150 Got SIGPIPE. Where it came from???
            Some items are not refreshing, the triggers for these items don't trigger due to Error:
            Host is unavailable.
            If I add to my trigger {HOSTNAME:agent.ping.last(0)}=0 this new condition:
            For the item:
            Type zabbix agent
            Key agent.ping
            update interval 30
            Keep history 7
            Keep trends 365
            My zabbix_agentd.conf:
            ServerPort=10051
            ListenPort=10050
            StartAgents=5
            #RefreshActiveChecks=120
            #DisableActive=1
            #EnableRemoteCommands=1
            DebugLevel=3
            PidFile=/var/run/zabbix-agent/zabbix_agentd.pid
            LogFile=/var/log/zabbix-agent/zabbix_agentd.log
            Timeout=3
            UserParameter=oracle[*],/opt/zabbix/zabora $1 $2
            It false triggers for some hosts. I had a switch problem the 22th, and some items don't refresh from that day.
            I tried restarting the agents, checking the hostnames in the zabbix_agentd.conf are the same as in the zabbix gui (case sensitive), connection to IP.
            related post: http://www.zabbix.com/forum/showthread.php?t=15112
            • bashman
              • Dec 2009
              • 432
              It could be a timeout problem, I'll try to increase Timeout=3 to Timeout=5 in zabbix_server.conf.
              • elvar
                • Feb 2008
                • 226
                For what it's worth, I posted a couple days ago on some agent.ping.nodata(300)}=1 threads saying that raising my timeout fixed the problem (which it did for one host) but after switching other hosts to that same trigger I kept having problems. Even if I upped my timeout to 30 (max) I still see this trigger fire even though the host is up and I see successful agent.ping attempts in the debug log output of the server.
                23922:20091229:063129.511 In get_value_agent() host:'Host' addr:'Remote.IP.Here' key:'agent.ping'
                 23936:20091229:063130.702 In evaluate_function('Host:agent.ping.nodata(300)')
                 23936:20091229:063130.702 End of evaluate_function('Host:agent.ping.nodata(300)',value:'0'):SUCCEED
                I have yet to hammer out exactly what's causing these false alarms but it's extremely frustrating. It feels like a bug but I can't pinpoint it. I did notice that the last time I got a value:'1' in the debug logs for that check it triggered the alert but I don't understand why it received a value of '1' when I can see the host is up, the agent is running, and all my manual ping requests are coming back fine. Is the remote agent bombing out? Is the Zabbix Server having issues? *sigh*
                • bashman
                  • Dec 2009
                  • 432
                  In the Zabbix Manual v1.6 I can see that agent.ping must have type "ZABBIX trapper". The host should periodically send data for this parameter using zabbix_sender.
                  • bashman
                    • Dec 2009
                    • 432
                    I tried that, but I still get false alarms, my trigger agent.ping.nodata(180) doesn't work.
                    Can the function nodata work with agent.ping?
                    • MrKen
                      • Oct 2008
                      • 652
                      I must be going blind. What page is that on?
                      MrKen
                      • bashman
                        • Dec 2009
                        • 432
                        Sorry it's on page 130 > Example 8:
                        Use of function nodata():
                        {zabbix.zabbix.com:tick.nodata(180)}=1
                        ‘tick’ must have type ‘ZABBIX trapper’’. In order to make this trigger work, item
                        ‘tick’ must be defined. The host should periodically send data for this parameter
                        using zabbix_sender. If no data is received within 180 seconds, the trigger value
                        becomes TRUE.
                        • bashman
                          • Dec 2009
                          • 432
                          My trigger works fine now with this expresion:
                          {HOSTNAME:agent.ping.last(0)}=0 | {HOSTNAME:agent.ping.sum(#3)}<1
                          • bashman
                            • Dec 2009
                            • 432
                            It works now with this expresion:
                            {HOSTNAME:agent.ping.max(300)}<1 | {HOSTNAME:agent.ping.nodata(300)}=1
                            zabbix agent version: 1.6.6
                            zabbix server version: 1.8
                            • 1berto
                              • Sep 2018
                              • 182
                              #15
                              Having the same issue here, zabbix 4.0 :O ...
