agent.ping with nodata false triggers
  • bbrendon
    • Sep 2005
    • 873
    #16
    You'll need a new thread with some new diagnosis. The software has changed a lot in the past 8 years.
    Unofficial Zabbix Expert
    Blog, Corporate Site
    • _Andrey
      • Jul 2013
      • 27
      #17
      I think i figured out what's the problem: no data () trigger function seems to be independent from item timer. Looks like its just checks data every N seconds and if the same time interval is set for item update interval - sometimes its spontaneously triggers as no data...
      Setting N+agent_timeout sec for trigger timer (where N = item update interval) has solved problem for me.
      • _Andrey
        • Jul 2013
        • 27
        #18
        Yeah, had read that, it is an important thing too, thanks. But i experienced this issue with 40 and 60 and even 120 sec update interval too. Thought that my answer might be helpful in similar case.
