pfSence current states
  • Lozzano
    • Jan 2011
    • 12
    Hi guys,
    Im getting to know Zabbix a bit now, and it's really awesome! Now I wanted it to talk to my pfSence over SNMP, which also works fine, but how do I make it show me the current states? If I choose the item called states, it gives me the maximum allowed states, which I am not interrested in. I'd like it to warn me before it reaches 10k states
    - Lozzano
  • troffasky
    • Jul 2008
    • 639
    If it doesn't show up when you snmpwalk your device [snmpwalk .... | grep -i state] then you probably won't be able to monitor it with SNMP.
    • Lozzano
      • Jan 2011
      • 12
      Funny thning happend, it timed out.. But when I check the same pfSence through the Zabbix snmp system it responds just fine? Any ideas?
      • troffasky
        • Jul 2008
        • 639
        Check it's the same community, same SNMP version, same host. Failing that, try and compare a packet capture of snmpwalk and Zabbix to the same host.
