Hi All,
I got a Supermicro ATOM Blades Server on which I use IPMI. A simple IPMI command is working fine :
/usr/bin/ipmitool -H $hostname -L User -U $login -P $password sdr
System Temp | 26 degrees C | ok
CPU Temp | 29 degrees C | ok
FAN 1 | 5210 RPM | ok
FAN 2 | 5025 RPM | ok
CPU Vcore | 1.15 Volts | ok
Vichcore | 1.04 Volts | ok
+3.3VCC | 3.26 Volts | ok
VDIMM | 1.52 Volts | ok
+5 V | 4.99 Volts | ok
+12 V | 11.98 Volts | ok
+3.3VSB | 3.26 Volts | ok
VBAT | 3.15 Volts | ok
Chassis Intru | disabled | ns
PS Status | 0 unspecified | nc
I configure each Item in a specific IPMI for ATOM template.
Everything is working except FAN 1 & FAN 2 Items.
I cannot get the values.
Those IPMI request are done by a zabbix proxy, I got in the zabbix_proxy.log file :
5200:20110826:193757.368 Item [hostname:fan-2] is not supported
5202:20110826:193758.183 Item [hostname:fan-1] is not supported
I do not understand why. I got some items with space in it like "CPU Vcore" or "+5 V". The only difference I can find is that there is a space before a number.
Is someone has this kind of issue ? Is this a bug ?
I manage to use an external script to work around this problem but this is frustating I would like to centralize all configurations.
Regards,
Laurent
Regards,
Laurent
