SLA calculation on IT Services
  • ariatti
    • May 2012
    • 23
    How it's calculated the values ​​of SLA in IT services?
    Example:
    - Service 1
    --- Trigger 1
    --- Trigger 2
    If the SLA of Trigger 1 was 0.02 and the SLA of Trigger 2 was 0.04
    The SLA of parent service (Service 1) should be 0:06?
    Thank's in advance!
    Sorry by my english...
  • ariatti
    • May 2012
    • 23
    anyone can help me on this?
    • ariatti
      • May 2012
      • 23
      Any zabbix expert can answer me this?
      • linuxgurugamer
        • Oct 2010
        • 68
        It should be the lower of the two
        • ariatti
          • May 2012
          • 23
          But it is not. There is some kind of calculation that I did not understand what is...
          • dissect
            • Nov 2012
            I know this is a very late reply but to help others understand.
            You cannot add 2 SLAs to each other. The best way to think of this is what happens when both SLAs reach 100%? You cannot violate an SLA by 200%.
            So instead Service 1 is an average of Trigger1 & Trigger2
            So to use your example: Trigger 1 = 0.02 and Trigger 2 = 0.04
            Makes: Service 1 = 0.03%
            You calculation would be: =(0.02+0.04)/2
            • m_gularte
              • Jul 2012
              • 85
              Hmm...
              I'm not sure... I made a test one day and the result was:
              Service 1 = 0.04%
              It takes the highest value. Although, from what I noticed, the results can be different depending on the version in use. For example, if a trigger is in state unknown, old zabbix versions calculate that as downtime. Nowadays, unknown state it's not used in sla math (apparently).
              But, as i said... i'm not sure, i've been doing these tests in 1.8.12, 1.8.14, 2.0, 2.0.1 and 2.0.2, i don't remember anymore. Is like that question about "Use custom multiplier", some people say that the default value keep changing from version to version, there are topics about this issue...
