FreeBSD 9.0 - Zabbix2-Agent Supported Options
  • GVJoshua
    • Nov 2012
    I've just installed Zabbix 2 on my FreeBSD 9.0-RELEASE box. I then installed the Zabbix 2 Agent on the same box but am running it as a different user.
    I added the host (itself) to Zabbix, then set up a ping monitor, and that works. But if I do system.cpu.util or system.cpu.load. It says that they are not supported.
    However, the list I found says that FreeBSD should support those items but yet they come up as unsupported?
    Can anyone direct me in how to troubleshoot this?
