create.sql.gz: No such file or directory
  • acvoliveira
    • Sep 2015
    I've donwloaded the zabbix 3.4 ubuntu version to install it in raspberry pi, but during the instalation it couldn't find - > create.sql.gz: No such file or directory.
    I've searched for the file, and it wasn't downloaded.
    I've followed the instructions step-by-step.
    pi@raspberrypi:/usr/local/src $ ls -la /usr/share/doc/zabbix-server-mysql/
    total 284
    drwxr-xr-x 2 root root 4096 Mar 16 12:34 .
    drwxr-xr-x 1405 root root 53248 Mar 16 12:34 ..
    -rw-r--r-- 1 root root 15591 Jun 4 2017 changelog.Debian.gz
    -rw-r--r-- 1 root root 189330 Dec 21 2016 changelog.gz
    -rw-r--r-- 1 root root 8446 Aug 12 2016 copyright
    -rw-r--r-- 1 root root 1212 Jun 5 2016 NEWS.Debian.gz
    -rw-r--r-- 1 root root 1096 Mar 27 2014 README.Debian
    Where I can download it seperatly, so I can finish the installation?
  • spyder76a
    • Oct 2018
    The documentation is incorrect (possibly depending on the flavour of Debian you are using):
    "https://www.zabbix.com/documentation/4.0/manual/installation/install_from_packages/debian_ubuntu#importing_data" states to go to path: '/usr/share/doc/zabbix-server-mysql/create.sql.gz', however I have no file of this name anywhere on the system. Instead I found the files (data.sql.gz images.sql.gz schema.sql.gz) in '/usr/share/zabbix-server-mysql' which appears to follow the same method as for proxy.
    I am using Kali linux [Linux Sentinel 4.16.0-kali2-amd64 #1 SMP Debian 4.16.12-1kali1 (2018-05-28) x86_64 GNU/Linux]
    Follow the instructions here: https://www.zabbix.com/documentation...importing_data to point "Creating database" then:
    cd /usr/share/doc/zabbix-server-mysql/
    zcat ./schema.sql.gz | mysql -uzabbix -p zabbix
    zcat ./images.sql.gz | mysql -uzabbix -p zabbix
    zcat ./data.sql.gz | mysql -uzabbix -p zabbix
    Try to go from there.....
    • gbl31
      • Dec 2018
      Same problem for me. I am installing zabbix 4.0
      I am a beginer with zabbix
      • onionsgalore
        • May 2019
        I apologize for the necro, but this thread is the first result for this issue on google:
        THE SOLUTION
        Certain files are not where they are supposed to be after installing zabbix-server-mysql and zabbix-frontend-php if `apt update` is not ran after installing the zabbix package. Remember to run `apt update` immediately after `dpkg -i /path/to/package.deb` and BEFORE `apt install zabbix-server-mysql zabbix-frontend-php`.
        The reason for this is that installing the Zabbix package makes changes to your systems repos, so you need to update the list of available packages to use the new repository.
        • coffeverton
          • Sep 2019
          The command is indeed wrong.
          I found that the files are not in the location described in the tutorial. They are stored here:
          /usr/share/zabbix-server-mysql/
          So the command should be:
          zcat /usr/share/zabbix-server-mysql/schema.sql.gz | mysql -uzabbix -p zabbix
          • ZaBeast
            • Sep 2019
            • 42
            I have also stumbled on this error with the wrong path, so I have documented everything in this guide for Rasbian OS:
            https://bestmonitoringtools.com/how-...y-pi-raspbian
            I hope it helps.
            • majed17
              • Oct 2019
              • 21
              i am on Fedora 30, and there is no such a file, not anywhere
              in /usr/share/ there is a zabbix folder and zabbix-mysql folder
              in /usr/share/doc/ there is also a zabbix folder zabbix-agent, zabbix-release, and zabbix-server
              locate create.sql
              has an empty result, how to proceed?
              • majed17
                • Oct 2019
                • 21
                the package zabbix-server-mysql was not installed
                • ZaBeast
                  • Sep 2019
                  • 42
                  There is no installation packet for Fedora on offical Zabbix site. You can compile Zabbix on Fedora or install Zabbix on another OS using this step-by-step guides: CentOS/RHEL, Ubuntu, Debian, Rasbian.
                  • majed17
                    • Oct 2019
                    • 21
                    dear, you can use the guide for rhel8, and from experience fedora is the best distro! don't want the paranoid arclinux, the disbelievers of opensuse, the profanity of centos, the trolls of ubuntu, did i miss any ?
                    • ZaBeast
                      ZaBeast commented
                      You can't use Rhel8 guide for fedora 30, I try that already, you must compile Zabbix on Fedora. BTW, Debian is the best ! (I m inviting trolls lol)
                  • matz
                    • Jul 2017
                    Problem is dpkg exclude list, so:
                    nano /etc/dpkg/dpkg.cfg.d/excludes
                    and comment doc exclude
                    # Drop all man pages
                    path-exclude=/usr/share/man/*
                    # Drop all translations
                    path-exclude=/usr/share/locale/*/LC_MESSAGES/*.mo
                    # Drop all documentation ...
                    path-exclude=/usr/share/doc/*
                    # ... except copyright files ...
                    path-include=/usr/share/doc/*/copyright
                    # ... and Debian changelogs
                    path-include=/usr/share/doc/*/changelog.Debian.*
                    And comment third drop, so after comment this file should look like this:
                    #path-exclude=/usr/share/doc/*
                    Next install or reinstall
                    apt reinstall zabbix-server-mysql zabbix-frontend-php zabbix-apache-conf zabbix-agent
                    and we have our file in: /usr/share/doc/zabbix-server-mysql*/create.sql.gz
                    • idv
                      • Jan 2021
                      I tryng to install Zabbix 5.0 in my Ubuntu 20.04 LTS but I have alto of problems.
                      eg:
                      root@ubuntu:/home# zcat /usr/share/doc/zabbix-server-mysql*/create-sql.gz | mysql -uzabbix -p zabbix
                      gzip: /usr/share/doc/zabbix-server-mysql*/create-sql.gz: No such file or directory
                      Why it happens?
                      Anyone can hel me please?
                      • kac
                        • Jan 2021
                        for Ubuntu 20.04 you should to edit file
                        Please do next:
                        or
                        vi /etc/dpkg/dpkg.cfg.d/excludes
                        and comment next:
                        to
                        then you need to reinstall zabbix packages for example
                        after that you will have files in
                        • Amiram
                          • Feb 2021
                          • 68
                          I'm getting the same issue here at Zabbix(MySQL)5.2 running on Ubuntu 18.04.
                          I do not have any file at the
                          so no excludes here.
                          Any idea?
                        • disnator
                          • Jun 2020
                          I have found file create.sql.gz in /usr/share/doc/zabbix-sql-scripts/mysql/create.sql.gz
