I'm writing an application which delivers data from remote devices over an HTTP API. These devices are on a mobile data connection and have limited resources.
I wish to receive custom monitoring data over the HTTP API, relying on the security model designed in the application, and push that data to Zabbix directly (or indirectly) from node.js. I do not wish to use Zabbix Agent on the remote devices.
I see that I can use zabbix_sender to send data to a Zabbix server containing a pre-configured host. This works great. I intend to deliver monitoring data over my custom API, and when received give this data to zabbix_sender inside the server network.
The problem is there are many devices in the field and more are being added all the time. TL;DR:
When zabbix_sender provides a custom hostname which doesn't exist in Zabbix already, it fails.
I would like to auto-add discovered hosts, based upon new hostnames from zabbix_sender. How would I do this?
Also, extra respect if anyone can give examples of how to avoid zabbix_sender and send data directly from node.js to the Zabbix server. I mean: suggest an NPM package that you have experience using.
