Fire trigger if status don't change after 5 minutes
  • dragan979
    • Apr 2018
    • 49
    i have this trigger prototype which triggers alert if output is "failed"
    {Template AN AutoSys:an.job[{#JOB},an].str("failed")}=1
    i tried to use min() function:
    {Template AN AutoSys:an.job[{#JOB},an].str("failed").min(5m)}=1
    but got error:
    Incorrect trigger expression
  • Engraf
    • Sep 2014
    • 41
    For the Item with update interval of 1 min:
    {Template AN AutoSys:an.job[{#JOB},an].count(#5,"failed",eq)=5
    • andreft
      • Dec 2019
      but got error:
      Are you using this template to monitor CA Workload Automation Autosys Edition?
      If yes, where did you get the template?
