Question about upgrading RPM
  • felixchu@powerallnetworks
    • Jul 2014
    hi all,
    I am using RPM version of Zabbix 2.2.3. I have just updated the rpm to 2.2.5. I would like to ask if new version having database schema changes, will the rpm upgrade auto change it as well?
    I am planning to deploy zabbix as production, so I would like to know using rpm / source version in long term.
    Felix
  • EnigmA-X
    • Oct 2010
    • 116
    Use Google my friend:
    There are no upgrade SQL scripts anymore - database upgrade is performed by the Zabbix server/proxy.
