Parse error messages from web scenario checks as a macro
  • y3046308
    • Nov 2019
    I just setup dozens of web scenario checks in Zabbix.
    I also added triggers and one action for all the triggers.
    To test the action, i deployed a test bad web scenario check.
    However, an email message i got from the test only gave very high-level information:
    Problem: Service "Jira-QAS" is DOWN
    Application: CloudOps
    Problem started at 13:41:38 on 2019.11.20
    Problem name: Service "Jira-QAS" is DOWN
    Severity: High
    Status: PROBLEM
    Value: 1
    Original problem ID: 2314429
    What I want is to parse "Last error message of scenario ..." as a macro and put it in the "default message" in "Action".
    So it would look something like this:
    Severity: High
    Issue: Couldn't connect to server: Failed connect to jira-qas.aws.ca:443; Connection refused
    I tried different macros such as {ITEM.VALUE}, {EVENT.STATUS} but neither of them were good enough.
    Can anyone share some insights?
