Which timeout is valid for web scenario step from host monitored by proxy?
  • amandahlak
    • Jan 2020
    When using web scenarios, which Timeout parameter is valid for the step execution? The step timeout parameter or proxy timeout parameter?
    About steps execution:
    "The steps are periodically executed by Zabbix server in a pre-defined order. If a host is monitored by proxy, the steps are executed by the proxy."
    About step timeout parameter:
    "Zabbix will not spend more than the set amount of time on processing the URL (from one second to maximum of 1 hour). Actually this parameter defines the maximum time for making connection to the URL and maximum time for performing an HTTP request. Therefore, Zabbix will not spend more than 2 x Timeout seconds on the step.
    Time suffixes are supported, e.g. 30s, 1m, 1h. User macros are supported. "
    About proxy timeout parameter:
    "Specifies how long we wait for agent, SNMP device or external check (in seconds)."
