Zabbix Appliance migration
  • vmugutrao
    • Apr 2020
    Hi Experts,
    We use Zabbix 3.2 appliance for monitoring our infra, i saw it somewhere its not good to use appliance to monitor prod devices (What do you think ?).
    So i am planning to migrate our appliance to server based zabbix.
    Zabbix Appliance 3.2 --> Zabbix Server 4.4
    What will be the steps involved in order to migrate all data (Devices, Template, items, triggers etc) from appliance to server based zabbix ?
    Thanks in advance
  • biggreen
    • Mar 2019
    I am in search of this info as well.
    I am using the 4.0 appliance, and plan to spin up a proper server to run it.
    • aib
      • Jan 2014
      • 1615
      In my mind it is quite easy but long process.
      1) Stop old server and export data:
      - stop appliance (zabbix agent, zabbix server)
      - export MySQL database
      - stop MySQL daemon
      2) Start and preconfigure new server
      - install & update new server
      - install Zabbix Agent, Zabbix Server, Zabbix WEB frontend, etc
      - transfer exported DB to new server.
      - Stop all Zabbix daemons
      - Import zabbix DB and restart MySQL daemon. Check and fix any errors
      - start server and check that server starts without any error
      - start Agent, check web access
      - Login to frontend and do final checks
      Keep old appliance backup and exported DB until final steps of installation on new server.
      NB! I assume that new server will use same IP and same FQDN to avoid any additional configuration of local agents.
      Sincerely yours,
      Aleksey
      • vmugutrao
        vmugutrao commented
        Thanks for your response,
        Do you think there is any benefit with zabbix server over zabbix appliance ?
