Zabbix 5 does not work with PHP 5.6?
  • cesarsj
    • Dec 2018
    • 154
    In my company we only work with LTS version software; and most server OS is Slackware 14.2, which has only PHP 5.6 available. PHP 7 is for Slackware Current. Will I have to wait to release Slackware 15 to install Zabbix 5?
  • tim.mooney
    • Dec 2012
    • 1432
    The minimum version of PHP for Zabbix 5.0 is PHP 7.2.
    Unless you're comfortable using PHP 7.2 from some other source (like compiled yourself), then you will have to wait to install Zabbix 5.0 until your preferred OS distribution has it available.
    • john21548945
      • Dec 2020
      I think this can be useful on your query which can let you stick with the OS on what you are if you change the OS then you have to go on a bit learning part.
      https://www.linuxquestions.org/quest...le-4175622728/
