Problems whitout any host associated
  • kuntz
    • Nov 2020
    I'm using Zabbix 4.0 LTS.
    I have a series of events NOT associated with any host, there are about a hundred.
    Is there a quick (and painless) way to eliminate them all?
    Thanks in advance.
  • NilsA
    • Sep 2020
    • 102
    Navigate to Monitoring -> Problems - uncheck everything and apply. Check the box at the top between "Time" and "Severity" -> Mass update -> Close problem.
    If you can't close the problems, you need to allow manual close in their triggers.
    • kuntz
      • Nov 2020
      Thank you for your answer NilsA.
      I've tried to allow the manual close, but the problems are associated to Windows Services that was automatically discovered and nothing change.
      I guess because there is no host associate to those items.
      Any other idea?
      Thanks.
      • kuntz
        • Nov 2020
        Actually I don't know how the host was removed.
        But the situation now is this
Name:	Screenshot 2020-11-06 115247.png
        • kuntz
          • Nov 2020
          I found the solution in this thread → https://www.zabbix.com/forum/zabbix-...data-in-zabbix
            Shouldn't all such things be deleted when host is removed? I have never seen an event with missing host...
