Monitoring SLA using alerts
  • rdenadai
    • Apr 2015
    is there anyway in Zabbix to monitoring SLA changes in the same way we check services?
    I mean, send an email to some user, when the SLA value for an specific item is low than the agreed?
    Thanks for the help
  • jeetusjeet
    • Oct 2014
    • 13
    There is no option to send any notifications based on SLA, at least for me. I was also looking for the same and tried so many options in zabbix.
    But, there is a workaround for this, You can use Discovery to check service uptime and create one action to send notification.
    Thanks,
    Jitendra
    • rdenadai
      • Apr 2015
      Thanks for the answer... i realized that there's no option for this... so i'll take the hard way, build a script to try to automate that, a python script called from zabbix or outside... still not decide about that.
      but thanks!
      • jeetusjeet
        • Oct 2014
        • 13
        It is good to hear from you.
        My only request is to please share that script once created because i never worked on scripts.
        Thanks,
        Jitendra
        • jeetusjeet
          • Oct 2014
          • 13
          If anyone can tell that is there any way to monitor Service UPTIME using DNS names and a way to send notification of Service uptime in zabbix?
          • dirckcopeland
            • Oct 2013
            • 50
            DNS Service
            jeetusjeet,
            Use the key:
            net.dns[<ip>,zone,<type>,<timeout>,<count>]
            net.dns[8.8.8.8,www.yourdomain.com,1,2)
            create an item with this key and then a trigger to go into a problem state if it equals 0
