Zabbix agent reading proc files
  • Amiram
    • Feb 2021
    • 68
    Hey all,
    I'm started to look into what the `zabbix-agent` is doing in order to understand the effect it has on my system.
    I have come across the fact that the agent is excessively reading the `/proc` files.
    • cmdline
    • stat
    Every 2seconds it read all the different pids cmdline and stat file.
    Any idea why?
    Why so frequently?
    What process/check is causing it?
    Thanks for the help
    Amiram
    • 5008
    process and logfile monitoring I suppose... depends on your update frequency I think.
    • Amiram
      • Feb 2021
      • 68
      The 'checker's that are causing this issue are the proc.*
      The `proc.cpu.util` and the `proc.mem` are reading those files in order to retrieve the requested data.
