file system monitoring
  • Filter
    Hi, I'm new to zabbix. So, I've just installed a zabbix server vesion:
    zabbix_server --version
    Zabbix server v2.4.7 (revision 56694) (12 November 2015)
    Compilation time: Nov 13 2015 11:41:19
    the server is ubuntu 14.04 LTS, kernel 3.13.0-68-generic
    I've installed agent on several nodes (also ubuntu 14.04 LTS, kernel 3.13)
    But, I'm not seeing zabbix report correctly on full file systems. i.e.
    when I test this by creating files on file system /var/log
    os it's 98% full, zabbix only tells me:
    "free disk space is less than 20% on volume /var/log ( the colour is orange)
    Also, when this volume is 100% full ( /var/log ) zabbix is only reporting :
    "free disk space is less than 20% on volume /var/log" ( the colour is orange)
    why is'nt this reported as 'high' with a Red colour?
    best regards
    Yngvi
    I suggest to get familiar with concepts of Zabbix first. The online documentation is a very good starting point.
    Regarding your question take a look at Items and Trigger in particular.
    The short answer to your question is that your Trigger likely has 20% statically defined in its name.
    E.g.: Free disk space is less than 20% on volume {#FSNAME}
    and the expression of the Trigger just checks the last value of the respective Item being below a certain threshold.
    E.g.: {Template OS Linux:vfs.fs.size[{#FSNAME},pfree].last(0)}<20
    Note that Items and Triggers related to file systems in the Template distributed with Zabbix are managed by so called Low-Level discovery.
    As being new to Zabbix, you might possibly also be interested in Some principles and practices I consider useful (not only) when using Zabbix at larger scale.
      thanks for the reply I'll read the this documentation and figure how to alter this!
      Yngvi
        OK, so I've created a new 'trigger prototype' under the relevant template->discovry ...
        and it works
        thanks a lot for your help
        best regards
        Yngvi
          Or u can juste write a powershell script (for instance) and then with the zabbix trapper you retrieve all the informations. I did this, I think it's the easiest way to do it !
          Announcement
          No announcement yet.
