How to Change Zabbix Appliance FrontEnd Language...
  • M.L
    • Dec 2021
    Hello community,
    I'm in Zabbix Appliance 5.0 LTS and I'm desperately looking for how to change the language of the Frontend/https ! (English To French)
    The French option is available on the GUI but it is grayed out
    And I can't find any information about it for the Appliance versions...
    Thanks in advance if you have the solution !!!
  • vladimir_lv
    • May 2022
    • 240
    Hi!
    You have to install additional locale on your Zabbix server. Don't forget to restart Apache (Nignx) after that.
    Example for RH and Apache:
    dnf -y install langpacks-fr.noarch
    service httpd restart
    • M.L
      • Dec 2021
      Thank you Vladimir for your feedback!
      What do you mean by "HR"?
      • M.L
        • Dec 2021
        I mean "RH"...
        • Atsushi
          • Aug 2013
          • 2028
          I think "RH" is "Redhat". If your appliance uses a RHEL (Red Hat Enterprise Linux) based OS, you will need to install langpacks for the locale you want to use and restart the php-fpm service.
          • vladimir_lv
            • May 2022
            • 240
            Originally posted by vladimir_lv
            Hi!
            Yes, I meant Redhat by RH
            • M.L
              • Dec 2021
              Hi Atsushi,
              Indeed RH must mean Red Hat! Thanks.
              The appliance is given in CentOS 8, I think CentOS is red hat, no ?
              Sorry, I'm not a linux pro...
              • Atsushi
                • Aug 2013
                • 2028
                CentOS is a distribution that rebuilds the RHEL source, so it is basically compatible. Most of the operations for RHEL can be used as is.
                • omdumo
                  • May 2022
                  I can't get change the language to spanish. I have an Appliance Zabbix on hyper V with ngnix and centos. I've worked in this tutorial but It's had been imposible
                  • Atsushi
                    Atsushi commented
                    Have you installed langpacks-es?
                • omdumo
                  • May 2022
                  yeah, look this:
Name:	2022-05-28 00_02_30-System Locale - Que es, como configurarlo en Centos Linux ✍️ - DriveMeca.png
                  • Atsushi
                    • Aug 2013
                    • 2028
                    Maybe you don't see Spanish in the language pull-down? If the percentage of translations is low(now 43%), you cannot select the language to display. I encourage you to join the Spanish translation team so that you can choose from the menu.
                    Localize Zabbix UI and Document:
                    If you set the display value of the es_ES line in the file /usr/share/zabbix/include/locales.inc.php to true, you will be able to select it from the pull-down menu.
                    • vladimir_lv
                      • May 2022
                      • 240
                      Zabbix web-interface still is not totally translated to Spanish. Currently only 43% of strings are translated: https://translate.zabbix.com/es/zabbix-60/. That is why you can not enable it.
                      • M.L
                        • Dec 2021
                        It worked for me with this command:
                        dnf -y install langpacks-en.noarch
                        Thanks a lot to you !
