How to add a Graph from a host to a dashboard?
  • P Sears
    • May 2022
    Hello, I have a graph I made from Configuration → Hosts /Graphs /Create graph. It's pretty nice, how can I include it on a dashboard or make it a favorite graph?
    thank you
  • markfree
    • Apr 2019
    • 874
    See if Dashboard documentation helps you.
    • markfree
      markfree commented
      Link fixed
  • P Sears
    • May 2022
    Add Widget/Graph (classic) / Graph Select / find the group/host/graph in the Select interface
    • noideawhatimdoing
      • Apr 2023
      Nope, doesn't help. haha I'm trying to figure out the same thing myself.
      • Atsushi
        • Aug 2013
        • 2028
        Hi noideawhatimdoing,
        The structure of the document may change if the version changes. If you look at the original URL, you can easily imagine the link to the document.
        • Hank42
          • Nov 2023
          Aparently, this is not supported(yet?) in 6.4- however, in older versions there were control buttons on the custom host graph you create. One of them is "add to favorites" and then from the dashboard, you can add a "favorite graph" widget. That last par tis still part of 6.4, but the buttons on the host graph are not, so I have no idea how to tag a graph as a "favorite", so this widget is useless in 6.4. Maybe I am missing something. the 6.4 documentation has no information on the topic(but the 3.4 documentation does)
          6.4 Dashboard:
          • Hank42
            • Nov 2023
            As a follow-up - P Sears said it right when he said "Add Widget/Graph (classic) / Graph Select / find the group/host/graph in the Select interface" - to expand on that, in 6.4, you need to select "Graph (classic)" and then your host graphs are searchable.
            • SaMaNZABBIX
              • Dec 2023
              hi,
              Please explain the necessary settings to make the attached graph
              Explanation that it is necessary to have both percentage lines in the graph.
              Thanks​
