Template modules removed with Zabbix 6.4
  • markfree
    • Apr 2019
    • 875
    With the release of Zabbix 6.4, OOTB template modules were removed and are no longer available.
    We can see that the "module" directory is absent in the Zabbix Git repository.​
    These template modules often complement some production templates and are very helpful in monitoring specific system components, where there's no need to monitor multiple aspects of the system.
    For example, the "Linux by Zabbix agent" template monitors multiple resources of a Linux system, which may not be necessary in every case. So, templates like "Linux memory by Zabbix agent" or "Linux filesystems by Zabbix agent" offer a more limited monitoring approach that may come in handy.​
    After searching the documentation, I was unable to find any reference to this change, neither in the "What's new" topic for version 6.4, nor in the "Template changes" topic.
    Has anyone else found any references to the removal of these templates?
  • Clontarf[X]
    • Jan 2017
    • 80
    Throwing in a me-too for this. I was very confused doing a fresh install of 6.4 and missing all the modules (and many other) templates that were inherited from previous versions. Would suck to have to go back to 6.0 or 6.2...
    • solution
      • Jun 2020
      • 272
      From version 6 onwards there are no more dependencies on official templates.
      You can disable items and discovery that you do not want to monitor.​
      Wellington
      • markfree
        • Apr 2019
        • 875
        I find this message to be very vague.
        As I said, the template modules often complement some production templates and are very helpful in monitoring specific system components, where there's no need to monitor multiple aspects of the system.
        Overall, my point was that there was no mention of the template modules removal.​
        • solution
          • Jun 2020
          • 272
          Wellington
          • markfree
            • Apr 2019
            • 875
            I didn't check the release notes only the docs, but thanks for the reference.
