Communication failure between agent and Zabbix Docker server.
  • rhuanpk
    • Apr 2023
    Hello there!
    Currently I have the following scenario:
    First server: I have the Zabbix components: server, gateway and web interface (along with a mysql database), all running via Docker containers.
    Second server: I have the Zabbix agent running via Docker as well.
    On the second server where I run the Zabbix agent, I want to monitor the other Docker containers running on that server and the operating system itself.
    In the web interface (on the first server) already configure the host that runs the Zabbix agent (I believe it is configured correctly).
    THE PROBLEM...
    In the web interface, inside the "Issues" section of the Zabbix agent host, it keeps telling me the error (which makes me not receive any information from the agent):
    Docker: Service is down
    In the Zabbix server container logs I have some error lines like:
    discovery rule "hostname:docker.images.discovery" became not supported: Cannot fetch data: Get "http://1.28/images/json": dial unix /var/run/docker.sock: connect: permission denied.
    However, running the command:
    zabbix_get -s domain.com -k system.hostname
    OR
    zabbix_get -s domain.com -k system.hw.cpu
    From inside the Zabbix server container I can get the information returned correctly , without any errors!​
    What could be going wrong?
