Zabbix Agent on OpenSUSE 15.5
  • SPG-DK11
    • Jul 2023
    Hi All,
    I've been trying to get the Zabbix Agent 2 to work on OpenSUSE 15.5, with the default 'Linux by Zabbix agent' template.
    However it always returns that the Zabbix agent is not available.
    As far as I can see, nothing is returned in the error logs. I've checked our firewall communication, 10050/51 are allowed both ways, and a bunch of other ports with no blocked network traffic between the agent and the zabbix server.
    I've tried both encryption and no encryption, both don't seem to work.
    For installation I've followed the installation procedure of: Download and install Zabbix 6.4 for SUSE Linux Enterprise Server 15 (SP4+)​
    The service of zabbix shows the status as running without an issue.
    Any ideas would be much appreciated, as we've a few hand fulls of OpenSUSE servers we'd like to add to monitoring.
    EDIT; I am running Zabbix 6.4.4
    Thanks!
  • Answer selected by SPG-DK11 at 03-08-2023, 09:39.
    SPG-DK11
    • Jul 2023
    Originally posted by Vermizz
    Do you have the correct zabbix server IP address (Server) and hostname value in the zabbix agent configuration file?
    For test run this:
    From zabbix server to remote agent run:
    zabbix_get -s yourhostIP -k agent.ping
    From zabbix server run:
    telnet yourhostIP 10050
    From your host:
    telnet zabbixserverIP 10051​
    Hi Vermizz,
    Thank you for the questions, the telnet from the host to the server worked fine, however server to host did not work. I got the error no route to host.
    After further investigation I totally forgot that OpenSUSE has a firewall within the OS itself as well, apart from our physical firewalls.
    After opening the ports 10050 and 10051 in the OpenSUSE firewall everything worked right away.
    • SPG-DK11
      • Jul 2023
      Any ideas would be much appreciated, till today I still have not been able to fix this.
      • Vermizz
        • Oct 2022
        • 33
        For test run this:
        From your host:
        • SPG-DK11
          • Jul 2023
          For test run this:
          From your host:
          Hi Vermizz,
