Get value from agent failed: ZBX_TCP_READ() timed out in Zabbix 6.4.5
  • dany2191
    • Aug 2023
    Good afternoon everyone, currently
    have implemented a zabbix server 6.4.5 which has been working without any problem with servers that have installed the zabbix agent from the same lan network, my problem arises when I install the zabbix agent on a server that is outside of my network and that I have a connection through a S2S VPN, when I register this host after a few seconds I get the following message
    HTML Code:
    "Get value from agent failed: ZBX_TCP_READ() timed out "
    , so far I have made the following discards :
    - Permissions at the Firewall level: Currently, all incoming and outgoing traffic from both networks to the zabbix server is allowed, an ICMP test has been carried out, telnet to port 10050 with success.
    -Logs in Agent and zabbix server: The logs in the Agent have been reviewed but nothing appears regarding any error, also the zabbix server logs have been reviewed, which shows the following information:
    HTML Code:
    "1217:20230802:183822.097 Zabbix agent item "perf_counter_en ["\Processor Information(_total)\% Privileged Time"]" on host "XXX-PE51" failed: first network error, wait for 15 seconds"
    -Response time check using zabbix_get: The following command was executed
    HTML Code:
    "zabbix_get -s XX.XX.XX.XX -k agent.ping"
    which shows the number "1" as a result.
    - Antivirus or other review: It has been reviewed that there are no blockages of any other application such as antivirus and firewall of the operating system, which does not present any type of blockage.
    - Review of zabbix forums where there were similar cases: I have made the review, several steps were followed without any success, the problem continues to persist, until I changed the timeout of the zabbix agent to more and the problem still persists.
    I have done all these tests and I don't know why this is happening.
    I would also like to indicate that the problem is only when I try to monitor these hosts through zabbix agent, I have carried out the test through SNMP towards the same hosts and if it works correctly.
    Please if you could help me.​
  • bcostapt
    • Nov 2023
    • 10
    Hello Dani, did you find out the answer for your problem? I have the same issue.
