Remote agent to also monitor camera (ping)
  • bigalnz
    • Sep 2023
    • 11
    I have Zabbix agent on a Windows PC reporting (active) over the internet to my Zabbix server.
    I would like this Windows Zabbis agent to also monitor a IP based camera on that network, and if it cant ping it for more than say 5 minutes in a row, report this error.
    Is this possible?
    Is it something like : UserParameter=CheckVPN,fping x.x.x.x | grep alive | wc -l
    Cheers
    Al
  • Hamardaban
    • May 2019
    • 2714
    icmpping[<target>,<packets>,<interval>,<size>,<timeout>]
      icmpping is executed on server/proxy. So pinging from agent cannot be done by using this item..
      But doing it with userparameter should work. Example looks usable.. you might want to use "fping -q" to ignore ping errors etc.. (Don't show per-probe results, but only the final summary. Also don't show ICMP error messages.)
      • Hamardaban
        • May 2019
        • 2714
        Yes - you are absolutely right - I forgot this... sorry
        If the host is under unix, then Userparameter.
        if under windows, then there is another solution​ - https://www.zabbix.com/forum/zabbix-...s-agent-by-wmi
        • dimir
          Zabbix developer
          • Apr 2011
          • 1080
          And don't forget to follow and vote for: https://support.zabbix.com/browse/ZBXNEXT-739
