Clarification regarding the proxy
  • andreagx
    • Oct 2021
    • 29
    I need some clarification regarding the proxy.
    The scenario is somewhat unique in the sense that the Zabbix server is located in a place with limited bandwidth.
    I was wondering if it's possible to configure the proxies to send data to the server only at night. Additionally, if it's possible to estimate the necessary bandwidth based on the number of hosts to monitor (approximately, not in bytes, of course).
    Thank you.​
    • 4993
    There is no scheduling for sending.. DataSenderFrequency in proxy config can be max 3600s , same for ProxyDataFrequency in server config..
    Active proxy will anyway connect every second for remote command tasks...
    If you kill whole connection and play around with ProxyOfflineBuffer​ ... maybe you can do something..
