Zabbix Server Memory Problem
  • onder
    • Apr 2022
    Hello everyone,
    I have a Zabbix server with the following specifications and I am experiencing memory problems. How can I solve this problem? Can I get your advice? Thanks
    System information
    16 CORE
    64 GB Memory
    Ubuntu 22.04 LTS
    Apache:2.4.52 (Ubuntu)
    MySQL: 8.0.36-0ubuntu0.22.04.1
    Zabbix: 6.4.14
    Parameter Value Details
    Zabbix server is running Yes localhost:10051
    Number of hosts (enabled/disabled) 397 396 / 1
    Number of templates 284
    Number of items (enabled/disabled/not supported) 74102 71055 / 2788 / 259
    Number of triggers (enabled/disabled [problem/ok]) 48328 46995 / 1333 [196 / 46799]
    Number of users (online) 87 6
    Required server performance, new values per second 852.34
    High availability cluster Disabled
    /etc/mysql/mysql.conf.d/mysqld.cnf
    [mysqld]
    user = mysql
    innodb_buffer_pool_size = 51G
    innodb_buffer_pool_instances = 48
    innodb_log_file_size = 12G
    join_buffer_size = 4M
    skip-name-resolve=ON
    bind-address = 127.0.0.1
    mysqlx-bind-address = 127.0.0.1
    key_buffer_size = 16M
    myisam-recover-options = BACKUP
    max_connections = 1000
    log_error = /var/log/mysql/error.log
    slow_query_log = 1
    slow_query_log_file = /var/log/mysql/mysql-slow.log
    long_query_time = 2
    log-queries-not-using-indexes
    log-slow-admin-statements
    log-slow-replica-statements
    log_bin = /var/log/mysql/mysql-bin.log
    binlog_expire_logs_seconds = 604800
    max_binlog_size = 100M
    /etc/apache2/apache2.conf
    DefaultRuntimeDir ${APACHE_RUN_DIR}
    PidFile ${APACHE_PID_FILE}
    Timeout 100
    KeepAlive On
    MaxKeepAliveRequests 200
    KeepAliveTimeout 3
    User ${APACHE_RUN_USER}
    Group ${APACHE_RUN_GROUP}
    HostnameLookups Off
    ErrorLog ${APACHE_LOG_DIR}/error.log
    LogLevel warn
    IncludeOptional mods-enabled/*.load
    IncludeOptional mods-enabled/*.conf
    Include ports.conf
    <Directory />
    Options FollowSymLinks
    AllowOverride None
    Require all denied
    </Directory>
    <Directory /usr/share>
    AllowOverride None
    Require all granted
    </Directory>
    <Directory /var/www/>
    Options Indexes FollowSymLinks
    AllowOverride None
    Require all granted
    </Directory>
    AccessFileName .htaccess
    <FilesMatch "^\.ht">
    Require all denied
    </FilesMatch>
    LogFormat "%v:%p %h %l %u %t "%r" %>s %O "%{Referer}i" "%{User-Agent}i"" vhost_combined
    LogFormat "%h %l %u %t "%r" %>s %O "%{Referer}i" "%{User-Agent}i"" combined
    LogFormat "%h %l %u %t "%r" %>s %O" common
    LogFormat "%{Referer}i -> %U" referer
    LogFormat "%{User-agent}i" agent
    IncludeOptional conf-enabled/*.conf
    IncludeOptional sites-enabled/*.conf
    ServerName localhost
    /etc/zabbix/zabbix_server.conf
    LogFile=/var/log/zabbix/zabbix_server.log
    LogFileSize=100
    PidFile=/run/zabbix/zabbix_server.pid
    SocketDir=/run/zabbix
    DBName=db
    DBUser=user
    DBPassword=password
    StartPollers=100
    StartPollersUnreachable=100
    StartTrappers=100
    StartPingers=100
    SNMPTrapperFile=/var/log/snmptrap/snmptrap.log
    CacheSize=5G
    HistoryCacheSize=1G
    HistoryIndexCacheSize=1G
    TrendCacheSize=1G
    TrendFunctionCacheSize=128M
    ValueCacheSize=5G
    Timeout=10
    FpingLocation=/usr/bin/fping
    Fping6Location=
    LogSlowQueries=0
    StartLLDProcessors=20
    StatsAllowedIP=127.0.0.1
    vmstat
    procs -----------memory---------- ---swap-- -----io---- -system-- ------cpu-----
    r b swpd free buff cache si so bi bo in cs us sy id wa st
    4 1 4130612 471388 493504 3937836 0 1 3 195 1 2 3 2 89 6 0
    topas
    top - 14:07:43 up 12 days, 16:01, 2 users, load average: 8.48, 7.58, 6.71
    Tasks: 749 total, 2 running, 747 sleeping, 0 stopped, 0 zombie
    %Cpu(s): 4.6 us, 4.5 sy, 0.0 ni, 72.8 id, 17.2 wa, 0.0 hi, 1.0 si, 0.0 st
    MiB Mem : 64394.4 total, 613.7 free, 59660.6 used, 4120.0 buff/cache
    MiB Swap: 4096.0 total, 72.0 free, 4024.0 used. 3551.5 avail Mem
    PID USER PR NI VIRT RES SHR S %CPU %MEM TIME+ COMMAND
    1052 mysql 20 0 59.7g 54.7g 16732 S 166.9 86.9 6449:11 mysqld
    1891 zabbix 20 0 13.2g 15700 9252 R 8.3 0.0 567:35.15
    mysql> SHOW VARIABLES LIKE 'max_connections';
    max_connections 1000
    mysql> SHOW STATUS WHERE `variable_name` = 'Threads_connected';
    Threads_connected 144
    mysql> SHOW VARIABLES LIKE 'innodb_log_file_size';
    innodb_log_file_size 12884901888
    mysql> SHOW VARIABLES LIKE 'innodb_buffer_pool_size';
    innodb_buffer_pool_size 57982058496
    mysql> SHOW VARIABLES LIKE 'table_open_cache';
    table_open_cache 4000
    mysql> SHOW VARIABLES LIKE 'query_cache_size';
    Empty set (0.01 sec)​
  • solution
    • Jun 2020
    • 271
    With this configuration you will have problems.
    Hardware memory: 64GB
    your configuration:
    innodb_buffer_pool_size = 51G + 1000 connections + other caches + zabbix server + other applications + O.S = +100GB (maybe) required.
    Use mysqltuner to find out the maximum that mysql will consume with the current configuration, and follow the tips, make adjustments.
    MySQLTuner is a script written in Perl that will assist you with your MySQL configuration and make recommendations for increased performance and stability. - major/MySQLTuner-perl
    Wellington
    • onder
      • Apr 2022
      solution thank you for your interest. Ok, I will run mysqltuner and reconfigure SQL. I will monitor it and share the result again.
