I’m working on an embedded hardware project using Yocto Project and OpenEmbedded OE Linux. I need to set up a “zabbix-proxy” to monitor remote devices (https://www.zabbix.com/documentation...toring/proxies). Unfortunately, I don’t have the option to use “apt install” on my operating system, so I’ll have to build it from the source. The OpenEmbedded “meta-oe” has a recipe for zabbix and zabbix-agent is available, but it doesn’t include zabbix-proxy.
Has anyone successfully implemented “zabbix-proxy” over OE Linux?
I’d really appreciate any help or guidance you can provide.
Cheers,
Cheers,
