Help creating a Template Graph
  • Ebae
    • Apr 2025
    Hello I am trying to create a graph in a template that uses an item from another template.
    I have Template A that applies to all of my hosts and I have Template B that only applies to some. I want Template B to create a graph that shows has values from Template A and Template B on it. I tried duplicating the item from A onto B, but got this error.
    • Cannot inherit item with key because an item prototype with the same key already exists.
    Is there a way to reference an item from one template into another or a different way to automatically create graphs that use items from multiple templates?
  • guille.rodriguez
    • Jun 2022
    • 120
    I think you need to create a calculated item in HOST A getting item value from HOST B
