Host Interface selections via SNMPv3
  • jimmy.mccubbins
    • Oct 2025
    • 19
    We are starting to pull in network devices via SNMPv3. We want to see the interface utilization on these devices. Each devices has between 5-15 interfaces on it, but we only want to monitor specific ones but the interfaces are not all named the same i.e..
    Router01- Fa0/1, F1/1
    Router02- Gi0/0, Gi0/0/1
    Router03-Tunnel01
    Router04- Tunnel01 and 02
    can we pick at any point in Zabbix to show only what I want instead of pulling it all in?
  • troffasky
    • Jul 2008
    • 640
    Check this:
    https://blog.zabbix.com/lld-filterin...-macros/24959/
    Alternatively...you can let LLD discover all the interfaces, disable LLD and then delete all the items for interfaces you are not interested in.
    If you leave the LLD discovery rule enabled and then make changes to discovered items, your changes will be overwritten next time it runs.
