SNMP Builder for Zabbix
  • giapnguyen
    • Aug 2009
    • 33
    I'm working on a snmp builder tool to browse, convert and insert snmp oid into a template. It still some minor bugs. I will post it soon. Here some of screenshots and features.
    Support snmp table
  • sersad
    • May 2009
    • 518
    qool
    when I can try?
    • giapnguyen
      • Aug 2009
      • 33
      Here you are
      Moderator Edit, Link broken, location preserved, spaces added to prevent clickable link:
      http:// yahgho. bytehost22. com/wiki/doku.php?id=blog:snmp_builder
      Features:
      • MIB Browser: you can select default MIB files or your own device MIBs to get OID tree. Click on the tree to retrieve value and information about a OID. Click to select the OID as Zabbix's item.
      • OID Table support: it assume that a OID whose name's end with string 'Table' is a OID Table. OID Table will retrieve with all it's indexes. Click on the cell to select the index as Zabbix's item. If my above assumption is wrong, you can use the checkbox “view as table” to switch between table and normal view.
      • Column selection: On OID Table, click on a header will select a whole column as Zabbix's items. It's useful if you create SNMP template for a 48 ports switch.
      • Auto convert: I implement a simple convert from SNMP Type to Zabbix's item.
      If u got any bugs, please post here.
      • Firm
        • Dec 2009
        • 342
        giapnguyen,
        Great work! It's one of most awaiting features I've wished to see. But I have small problem: can't browse MIB tree. After selecting MIB from drop-down list I have the following in the left sub-window.
        • giapnguyen
          • Aug 2009
          • 33
          Hi Firm
          Yeah, my code heavily rely on snmp OS commands. I work on Ubuntu 9.10 and still not sure the output is same in other *nix. So please tell what OS, you install zabbix and try to run from OS prompt
          snmptranslate -Ts -M <your MIBS_ALL_PATH> -m SNMPv2-MIB
          Give me the output, and I will know why it don't render the oid tree
          • ericgearhart
            • Jan 2009
            • 115
            Awesome!
            I just want to add that from your screenshots this looks awesome... easy SNMP integration was the one thing I was really missing from Cacti.
            I will give it a shot on my install of Zabbix (version 1.8, on CentOS 5.4) and post back if I have problems
            • Firm
              • Dec 2009
              • 342
              giapnguyen,
              CentOS 5.3 x86. The output is attached.
              • mrspy
                • Oct 2009
                I'm having the following problems:
                * Undefined index: templateid[/home/zabbix/public_html_svn/snmp_builder.php:125]
                * Undefined index: oids[/home/zabbix/public_html_svn/snmp_builder.php:126]
                * Undefined index: viewtype[/home/zabbix/public_html_svn/snmp_builder.php:127]
                If I change the template, nothing happens...
                If I change the MIB I have the following errors:
                    * Undefined index: items[/home/zabbix/public_html_svn/snmp_builder.php:576]
                Zabbix Server v1.8 (revision 8565)
                Zabbix Frontend SVN revision 8917
                Ubuntu 8.04.3 LTS
                Tested with Firefox and Chrome
                • mrspy
                  • Oct 2009
                  Hummm, in Zabbix 1.8 (revision 8565) frontend this problem does not occur...
                  • giapnguyen
                    • Aug 2009
                    • 33
                    Originally posted by Firm
                    giapnguyen,
                    Your output is fine. It's same with mine. I narrow down your problem to (1) snmptranslate not in search directory of apache's user, so it can't lauch the command; (2) there is a permission problem prevent snmptranslate run from php script (maybe because of selinux, apparmor, php.ini ...)
                    I glad to use php's snmp api to avoid OS-dependent problems but unfortunately it don't have sufficient features. I will install a CentOS 5.3 to check it.
                    You can try create a test.php in zabbix web dir contains:
                    PHP Code:
                    <?php
                        exec
                    ("snmptranslate -Ts -M /usr/share/snmp/mibs -m SNMPv2-MIB 2>&1"$results);
                    print_r($results);
                    Browse the test.php to see what happen when run snmptranslate from web.
                    • giapnguyen
                      • Aug 2009
                      • 33
                      Ubuntu 8.04.3 LTS
                      LOL, it is because I use index without check it existed or not - it's my bad but php accept it. Maybe in this version (debug purpose), developer increase error report level (E_NOTICE), than the warning showed.
                      • Firm
                        • Dec 2009
                        • 342
                        giapnguyen,
                        It works now. The problem was in PHP safe_mode=On that has prevented execution of all programs except from the directory set by safe_mode_exec_dir. After turning safe_mode=Off it works as should.
                        • ericgearhart
                          • Jan 2009
                          • 115
                          Just to help folks out, I was getting this error in /var/log/http/error_log:
                          PHP Fatal error:  Call to undefined function json_encode() in /var/www/html/snmp_builder.php on line 421
                          Installing php's json fixed that:
                          yum -y install php-pecl-json
                          so that at least I get the same page as the previous person posting to this thread who was having problems with CentOS
                          I'm on CentOS 5.4, and the php json pecl extension wasn't installed it looks like
                          • ericgearhart
                            • Jan 2009
                            • 115
                            I was able to test this today, and it works! I pointed snmpbuilder at a Cisco 2960G switch here at work and added a few interface items... as you can see at the bottom I also get the "Undefined index" errors but it seems to work OK nevertheless. I'm on CentOS 5.4.
                            The screenshot speaks for itself:
                            • giapnguyen
                              • Aug 2009
                              • 33
                              #15
                              I think zabbix already use json to draw map. Whatever php-json is required.
