SNMP Builder for Zabbix
  • dougbee
    • Apr 2011
    • 68
    #226
    Originally posted by da_oli
    Hi all,
    i tried the snmp builder on zabbix 1.8.8 on debian 6
    i applied all the patches described in wiki
    at the first time, it was possible to read out something from the device, but i wasn't able to add it as a item.
    i added some new mibs, like snmpv2 and tried it again, but now there is no result and the window with oid/name remains empty
    i also waited for about 5 minutes, but there is still nothing to see.
    does anybody have an idea?
    greets
    oliver
    Can you look at the page source, to see if the text is actually present but not getting rendered? I ran into this yesterday, it was because I had a typo (missing comma separator) in the jsLoader.php file..
    • lndgoncalves
      • Apr 2010
      • 29
      #227
      Zabbix 1.9.5
      error zabbix 1.9.5
      Non-static method CTemplate::get() should not be called statically [snmp_builder.php:563]
      Undefined index: host [snmp_builder.php:565]
      • sire
        • Jul 2010
        • 210
        #228
        Originally posted by lndgoncalves
        error zabbix 1.9.5
        Zabbix 2.0 and its 1.9 pre-releases differ quite a lot from 1.8, thus snmp_builder.php will not work on 1.9 and newer versions without changing its code. However this is a solvable task.
        Regards,
        Sergey Syreskin
        Monitored hosts: 2646 / Active items: 23604 / Server performance: 765.74
        Temporary out of Zabbix business
        • sire
          • Jul 2010
          • 210
          #229
          A SNMP Builder update
          Hi all,
          I have slightly updated SNMP Builder code.
          New features:
          • Zabbix 1.8.x internationalization support;
          • Changed some interface labels;
          • OID tree and Information screen elements are a bit wider now;
          • Changed OID selection color to something blueish;
          • "Clear" button clears OID selections;
          • Selectable SNMP version: 1 or 2c;
          • SNMP host port can be specified in host address field as 192.168.1.1:8161;
          • SNMP host's port is saved in items being created;
          • Support of new SNMP data types: INTEGER32, Unsigned32, Counter64;
          • Automatic selection of units and delta mode for if(In|Out)Octets and if(HCIn|HCOut)Octets OIDs;
          • Polling interval, keep history and keep trends item parameters can be specified by user;
          • Create graphs for numeric OIDs.
          Installation Instructions
          1. You need a clean Zabbix installation with no previous versions of SNMP Builder installed. Otherwise you should either uninstall old SNMP Builder or change my patch file.
          2. Change directory to your web root or where your Zabbix frontend files leave. For me it is /usr/share/zabbix.
          3. Apply patch by issuing command zcat snmpbuilder.diff.gz |patch -p1
          4. Untar SNMP Builder image files from snmpbuilder_imgs.tar.gz to /usr/share/zabbix/snmp_builder/imgs or where your Zabbix frontend leaves.
          Thanks go to:
          • GiapNguyen for SNMP Builder
          • Alixen, jhgrc and others for their patches
          This patch is created for Zabbix 1.8.12rc1, but should probably work with Zabbix 1.8.11 and even 1.8.10.
          Bug reports and suggestions are welcome.
          Regards,
          Sergey Syreskin
          • sire
            • Jul 2010
            • 210
            #230
            SNMP Builder For Zabbix 2.0
            Put images to /usr/share/zabbix/js/jquery/themes/mib/
            Regards,
            Sergey Syreskin
            • sire
              • Jul 2010
              • 210
              #231
              SNMP Builder updated
              Updated versions of my patches.
              Added MIB file upload. In order to make it work, chown /usr/share/snmp/mibs (or wherever your MIBs are located) to the user id of your web server (usually it is apache, httpd, www-data). Also correct $mibs_dir in snmp_builder.php if needed.
              If uploads fail, set upload_tmp_dir = /tmp variable in php.ini.
              P.S. Do my patches work for you, are there any bugs/suggestions? I need your feedback.
              Regards,
              Sergey Syreskin
              • rubendob
                • Apr 2012
                • 36
                #232
                Help guys
                Hello community
                I have a recently created Zabbix installation, 1.8.11, I want to know if is possible to run Snmp-Builder with these version. Actually ,I'am a little bit confused, I'm trying to install Snmp-Builder, downloading the code from
                But then there is the explanations of the wiki here
                http://www.zabbix.com/wiki/howto/mon...p/snmp_builder
                So I really don't know what to do, Also I read comments in these post of people (amazing) who develop its own patches and there is more than one Oo
                Can somebody give some guide about what to do exactly? I start from new Zabbix 1.8.11
                Any help will be awesome!
                • sire
                  • Jul 2010
                  • 210
                  #233
                  rubendob,
                  The version on github is outdated, it was modified 2 years ago. And it will not work on Zabbix 1.8.11 without modifications.
                  Regards,
                  Sergey Syreskin
                  • rubendob
                    • Apr 2012
                    • 36
                    #234
                    Snmp-builder
                    Hi Sire
                    ok, then I have to:
                    -1)Deploy snmp-builder from github
                    - 2) Do the hacks (because code is old)
                    question
                    what hacks exactly? There are some explanations in github web and some other differents in Wiki so:
                    what modifications I have to do or what hacks/patches I have to install in order to run withou issues snmp-builder?
                    Thanks!
                    PS:excuse me guys but it is my first approachs to snmp-builder :/
                    • rubendob
                      • Apr 2012
                      • 36
                      #235
                      Don't know how to install
                      Originally posted by sire
                      Hi all,
                      I have read some pages of thread and I have found you have version of snmp-builder compatible with 1.8.11, however,
                      - Does I have to download original snmp-builder code from the autor?
                      - And then patch it with your code?
                      Sorry for lot of questions.
                      thanks
                      • sire
                        • Jul 2010
                        • 210
                        #236
                        No need to to download original code. You need just clean Zabbix install to apply my patches.
                        Regards,
                        Sergey Syreskin
                        • rubendob
                          • Apr 2012
                          • 36
                          #237
                          error?
                          Hi Sire
                          this is what is happening when I follow the steps
                          # cd /var/www/html/zabbbix
                          # zcat snmpbuilder.diff.gz |patch -p1
                          patching file include/locales/en_gb.inc.php
                          Hunk #1 FAILED at 2499.
                          1 out of 1 hunk FAILED -- saving rejects to file include/locales/en_gb.inc.php.rej
                          patching file include/locales/ru_ru.inc.php
                          Reversed (or previously applied) patch detected!  Assume -R? [n]
                          How can I fix it?
                          EDIT: just to comment, version of Zabbix is latest stable, 1.8.11. If now I click on Administration>Snmp Builder this is what can i see of the bottom of the page
                          Use of undefined constant S_MIB - assumed 'S_MIB' [snmp_builder.php:451]
                          Use of undefined constant S_SNMP_VERSION - assumed 'S_SNMP_VERSION' [snmp_builder.php:470]
                          Use of undefined constant S_COMMUNITY - assumed 'S_COMMUNITY' [snmp_builder.php:474]
                          Use of undefined constant S_SNMP_BUILDER - assumed 'S_SNMP_BUILDER' [snmp_builder.php:476]
                          Use of undefined constant S_OID_TREE - assumed 'S_OID_TREE' [snmp_builder.php:496]
                          Use of undefined constant S_OID_DATA - assumed 'S_OID_DATA' [snmp_builder.php:526]
                          Use of undefined constant S_CLICK_TO_FORCE_VIEW_AS_TABLE - assumed 'S_CLICK_TO_FORCE_VIEW_AS_TABLE'
                          • sire
                            • Jul 2010
                            • 210
                            #238
                            Hi Sire
                            How can I fix it?
                            You have to manually apply a piece of patch concerning include/locales/en_gb.inc.php file. Open this file in a text editor, scroll to the bottom of the file. Put the translation strings before the line with a closing bracket and a semicolon ");". Translation strings are at the beginning of my patch and look like
                            PHP Code:
                            'S_SNMP_BUILDER' => 'SNMP Builder',
                            Remove plus "+" signs at the beginning of each line.
                            You may possibly need to ungzip my patch before you open it in an editor. Use gzip -d snmpbuilder.diff.gz command to do this.
                            Regards,
                            Sergey Syreskin
                            • rubendob
                              • Apr 2012
                              • 36
                              #239
                              Still in the fight
                              Hi Sire and other people
                              this is the bottom of the include/locales/en_gb.inc.php after make the changes you suggested
                              // class.citemkey.php
                                      'S_KEY_CANNOT_BE_EMPTY' => 'Key cannot be empty.',
                                      'S_NO_KEY_ID_PROVIDED' => 'No key id provided.',
                                      'S_NO_ITEM_KEY_PROVIDED' => 'Invalid item key format.',
                                      'S_INCORRECT_SIMPLE_CHECK_PARAMETER' => 'Incorrect simple check parameter.',
                                      'S_INCORRECT_SYNTAX_NEAR' => 'Incorrect syntax near \'%1$s\'',
                                      'S_INCORRECT_USAGE_OF_BRACKET_SYMBOLS' => 'Incorrect usage of bracket symbols. \'%s\' found after final bracket.',
                                      'S_INVALID_KEY_FORMAT' => 'Invalid item key format.',
                                      'S_NO_HOST_ADDR' => 'No host address provided',
                                      'S_INVALID_HOST_ADDR' => 'Invalid host address',
                                      'S_OID_LIST_IS_NULL' => 'OID list is null',
                                      'S_OID_IS_NULL' => 'OID is null',
                                      'S_INVALID_TYPE' => 'Invalid type',
                                      'S_OID_TREE' => 'OID Tree',
                                      'S_OID_DATA' => 'OID Data',
                                      'S_CLICK_TO_FORCE_VIEW_AS_TABLE' => 'Force view as table',
                                      'S_OID_NAME' => 'OID/Name',
                                      'S_DELTA' => 'Delta',
                                      'S_MIB' => 'MIB',
                                      'S_OID' => 'OID',
                                      'S_SNMP_VERSION' => 'SNMP Version',
                                      'S_COMMUNITY' => 'Community',
                                      'S_GRAPH_PARAMETERS' => 'Graph Parameters',
                                      'S_CANNOT_CREATE_GRAPH_FOR_NON_NUMERIC_ITEM' => 'Cannot create graph for non-numeric item',
                              then I run
                              patching file include/menu.inc.php
                              Hunk #1 succeeded at 174 with fuzz 2 (offset -41 lines).
                              patching file jsLoader.php
                              patching file snmp_builder/DynTable.js
                              patching file snmp_builder/snmp_builder.js
                              patching file snmp_builder/Tree.js
                              patching file snmp_builder.php
                              These are the files inside snmp_builder:
                              # ls -ls snmp_builder
                              total 188
                                8 -rw-r--r-- 1 root root   4497 Apr 23 10:27 DynTable.js
                               12 -rw-r--r-- 1 root root  10188 Apr 23 10:27 snmp_builder.js
                              168 -rw-r--r-- 1 root root 171825 Apr 23 10:27 Tree.js
                              Then, there is also another file of your installation
                              so I have downloaded and uncompress .tar.gz inside snmp_builder folder
                              total 192
                                8 -rw-r--r-- 1 zabbix zabbix   4497 Apr 23 10:27 DynTable.js
                                4 drwxr-xr-x 3 zabbix zabbix   4096 Apr 23 10:41 imgs
                               12 -rw-r--r-- 1 zabbix zabbix  10188 Apr 23 10:27 snmp_builder.js
                              168 -rw-r--r-- 1 zabbix zabbix 171825 Apr 23 10:27 Tree.js
                              Now I dont' see any errors on snmp-builder page inside Zabbix Administration but... OID tree is completely blank.
                              How can I check now? I have some ip of snmp device to check.
                              • sire
                                • Jul 2010
                                • 210
                                #240
                                rubendob,
                                Choose a MIB first, for example, IF-MIB, then enter the IP address and Community string of your SNMP device. That should be enough for the start.
                                Regards,
                                Sergey Syreskin
