SNMP Builder for Zabbix
  • sire
    • Jul 2010
    • 210
    #256
    Originally posted by chrisransley
    Is there a patch for v1.8.13
    The text leading up to this was:
    |diff -Nur zabbix-1.8.12.orig/frontends/php/include/locales/ru_ru.inc.php zabbix-1.8.12/frontends/php/include/locales/ru_ru.inc.php
    |--- zabbix-1.8.12.orig/frontends/php/include/locales/ru_ru.inc.php     2012-04-13 10:40:35.000000000 +0400
    |+++ zabbix-1.8.12/frontends/php/include/locales/ru_ru.inc.php  2012-04-11 17:15:19.000000000 +0400
    File to patch: /var/www/html/zabbix/include/locales/en_gb.inc.php
    patching file /var/www/html/zabbix/include/locales/en_gb.inc.php
    Hunk #1 FAILED at 2150.
    1 out of 1 hunk FAILED -- saving rejects to file /var/www/html/zabbix/include/locales/en_gb.inc.php.rej
    can't find file to patch at input line 62
    Perhaps you used the wrong -p or --strip option?
    Did you try this recipe? http://www.zabbix.com/forum/showpost...&postcount=238
    Regards,
    Sergey Syreskin
    Monitored hosts: 2646 / Active items: 23604 / Server performance: 765.74
    Temporary out of Zabbix business
    • chrisransley
      • May 2012
      When I access the file using vi or other text editors I get incorrect characters.
      PHP Code:
      +// SNMP Builder
      +       'S_SNMP_BUILDER' => 'Ã<98>üÿþÃ<80>Ã<82> SNMP MIB',
      'S_NO_HOST_ADDR' => 'Ã<9d>õ Ã<83>úð÷ðý Ã°Ã´Ã<80>õÃ<81> Ã<83>÷ûð Ã<81>õÃ<82>ø',
      'S_INVALID_HOST_ADDR' => 'Ã<9d>õôþÿÃ<83>Ã<81>Ã<82>øüÃ<8b>ù Ã°Ã´Ã<80>õÃ<81> Ã<83>÷ûð Ã<81>õÃ<82>ø',
      'S_OID_LIST_IS_NULL' => 'áÿøÃ<81>þú OID Ã¿Ã<83>Ã<81>Ã<82>',
      'S_OID_IS_NULL' => 'OID Ã¿Ã<83>Ã<81>Ã<82>',
      'S_INVALID_TYPE' => 'Ã<9d>õôþÿÃ<83>Ã<81>Ã<82>øüÃ<8b>ù Ã<82>øÿ',
      'S_OID_TREE' => 'Ã<94>õÃ<80>õòþ OID',
      'S_OID_DATA' => 'Ã<94>ðýýÃ<8b>õ OID',
      'S_CLICK_TO_FORCE_VIEW_AS_TABLE' => 'Ã<9f>Ã<80>øýÃ<83>ôøÃ<82>õûÃ<8c>ýþ Ã¿Ã<80>õôÃ<81>Ã<82>ðòøÃ<82>Ã<8c> Ã² Ã²Ã¸Ã´Ãµ Ã<82>ðñûøÃ<86>Ã<8b>',
      'S_OID_NAME' => 'OID/Ã<98>üÃ<8f>',
      'S_DELTA' => 'Ã<94>õûÃ<8c>Ã<82>ð',
      • chrisransley
        • May 2012
        Ok... got this to work.
        Got a problem when attempting to upload a MIB file though. I get:
        Command: cp -f /tmp/php200n4u /usr/share/snmp/mibs/v762b3.mib.
        Message: cp: cannot create regular file `/usr/share/snmp/mibs/v762b3.mib': Permission denied
        • sire
          • Jul 2010
          • 210
          #259
          Regards,
          Sergey Syreskin
          • sire
            • Jul 2010
            • 210
            #260
            Muca,
            what is the location of SNMP MIBs on your system, is it the same as specified in snmp_builder.php?
            Regards,
            Sergey Syreskin
            • sire
              • Jul 2010
              • 210
              #261
              Muca,
              Fix MIBS_ALL_PATH in snmp_builder.php to match your MIBs location.
              Regards,
              Sergey Syreskin
              • sire
                • Jul 2010
                • 210
                #262
                Originally posted by Muca
                Sire,
                I have already done that?
                It may be some JavaScript error. Are there any errors in the Apache log?
                Regards,
                Sergey Syreskin
                • chrisransley
                  • May 2012
                  H,
                  Upgraded to Zabbix 2.0 and installed SNMP builder script for v2.0. This is working apart from the fact that there are no images being displayed. No matter were I put the imgs folder.
                  In v2.0 were do the imgs go?
                  • sire
                    • Jul 2010
                    • 210
                    #264
                    H,
                    In 2.0 images go to zabbix/js/jquery/themes/mib/
                    Regards,
                    Sergey Syreskin
                    • chrisransley
                      • May 2012
                      I managed.
                      I place all image files in "js/jquery/themes/mib/" folder.
                      • atimonin
                        • Jun 2012
                        • 10
                        #266
                        Sire, (and maybe some others)
                        Great job! Thanks!
                        I've made some chane to snmpbuilder to make a more unerstandable
                        description for zabbix item (only for interfaces: ifTable - ifDescr).
                        Now it looks like (for Cisco in my case):
                        You may see ifDescr as zabbix item description? which is much more useful to me than oid + ifindex (especially for a large number of interfaces)
                        The only difference is in snmp_builder.php (see attachment)
                        It may be simpy done for other tables or oids, but I can't figure what ones and what to use as description...
                        • sire
                          • Jul 2010
                          • 210
                          #267
                          Great job! Thanks!
                          [ATTACH]4812[/ATTACH]
                          Hi atimonin,
                          I also considered this feature, but think of a situation when ifDescr changes. Item description will no more represent the corresponding interface.
                          Regards,
                          Sergey Syreskin
                          • atimonin
                            • Jun 2012
                            • 10
                            #268
                            Originally posted by sire
                            Hi atimonin,
                            Yes, possible. Also possible that even ifIndex changes (for ex. after conf change), but in all the case if I see ifDescr in item it's simplier to me to understand what's going on.
                            • frlan
                              • May 2012
                              • 18
                              #269
                              Any chance to get it into default distribution?
                              • atimonin
                                • Jun 2012
                                • 10
                                #270
                                You mean zabbix distibution or snmpbuilder on jithub?
