SNMP Builder for Zabbix
  • mario5046
    • Nov 2014
    Ok. I will try your method.
    Yes. Zabbix 2.4 is ok
    • spaww
      • May 2009
      • 178
      #452
      All,
      I found the bug about MIB Import.
      Is only update Zabbix-Extras and SNMP-Builder import process will work again in Zabbix 2.4.
      Special Thanks to Theo and Jader for help-me in debug !
      Adail Horst
      OCA/OCP - Oracle Application Server
      ZABBIX Certified Specialist
      http://www.spinola.net.br/blog (Blog sobre Zabbix e tecnologia)
      • mmidgett
        • Aug 2012
        • 14
        #453
        Im getting this error after running the zabbix extra script on 2.2.1
        Function: get_oid_tree. Command: /snmptranslate -Ts -M /usr/share/zabbix/extras/snmp-builder/mibs -m MIKROTIK-MIB. Error: 127. Message:
        Its the / in front that is keeping it from working. I can run the command without the /
        • spaww
          • May 2009
          • 178
          #454
          Mmidgett,
          Zabbix Extras 2.1 is for use with Zabbix 2.4... not Zabbix 2.2... the name of some funcions are changed since 2.4...
          Adail Horst
          • OriginNG
            • Dec 2014
            • 15
            #455
            Had the same problem and had net-snmp-utils not installed before I installed snmpbuilder. Fixed the issue by reinstalling snmpbuilder after I installed net-snmp-utils.
            Joop
            • AlexYoung
              • Jul 2013
              • 37
              #456
              Hi, I'm using 2.4 and getting nothing in my OID Tree and i've enabled error logging and it's saying
              PHP Code:
              Fatal error: Class 'JSON' not found in /usr/share/zabbix/snmp_builder.php on line 706
              the code is
              PHP Code:
               // Javascript GUI init
              if ($mib)
              $oid_tree = get_oid_tree($mib);
              $json = new CJSON();
              • donb
                • Feb 2015
                MIB tree works, no items or oid values in main screen...
                I have the same problem, where I cannot see or add the items in.. I am able to view the MiB tree.. but that's pretty useless if you cant import to template..
                CO-IP-IF-MIB: ciscoIPIfMIBCompliance1 ::= { ciscoIPIfMIBCompliances 2 }
                Cannot adopt OID in CISCO-IP-IF-MIB: ciscoIPIfMIBCompliance ::= { ciscoIPIfMIBCompliances 1 }
                Cannot adopt OID in CISCO-MAC-NOTIFICATION-MIB: ciscoMacNotificationMIBObjects ::= { ciscoMacNotificationMIB 1 }
                Cannot adopt OID in CISCO-MAC-NOTIFICATION-MIB: cmnMIBNotificationPrefix ::= { ciscoMacNotificationMIB 2 }
                Cannot adopt OID in CISCO-MAC-NOTIFICATION-MIB: cmnMIBConformance ::= { ciscoMacNotificationMIB 3 }
                Cannot adopt OID in CISCO-MAC-NOTIFICATION-MIB: cmnMIBCompliances ::= { cmnMIBConformance 1 }
                Cannot adopt OID in CISCO-MAC-NOTIFICATION-MIB: cmnMIBGroups ::= { cmnMIBConformance 2 }
                Anyone able to help with this?
                • richlv
                  • Oct 2005
                  • 3112
                  #458
                  for the record, https://www.zabbix.org/wiki/Snmp_builder tries to document how to get it running on different versions of zabbix, but it needs some help
                  • ciconet
                    • Feb 2015
                    • 15
                    #459
                    PHP Code:
                    the code is
                    PHP Code:
                    if ($mib)
                    Hi Alex
                    Are you solved this issue ?
                    I have the same....
                    • makemeasandwich
                      • Apr 2015
                      • 34
                      #460
                      any news on this topic ?
                      • spaww
                        • May 2009
                        • 178
                        #461
                        The version with zabbix extras (for zabbix 2.4) works fine !
                        Adail Horst
                        • makemeasandwich
                          • Apr 2015
                          • 34
                          #462
                          Yes the installation works. But the whole function about it doesnt't. So that its useless =( you cannot view anything.
                          Here is what I mean:
                          and the mib is not broken if I view it in ireasoning mib browser it works just fine.
                          • spaww
                            • May 2009
                            • 178
                            #463
                            makemeasandwich... works fine... I use this yesterday without problems...
                            what is your enviroment ? OS ? Install from sources or from packages ?
                            Adail Horst
                            • makemeasandwich
                              • Apr 2015
                              • 34
                              #464
                              hello,
                              can you show me a screenshot ? Im running ubuntu 14.04 LTS . Zabbix installed from Packages.
                              Thanks for the help!
                              Kind regards,
                              makemeasandwich
                              • makemeasandwich
                                • Apr 2015
                                • 34
                                #465
                                this is what I mean. This is a standard MIB that was included in extras.
                                I compared the mib with another mib browser.
                                The one from the zabbix add in doesn't show the OID's also the tree isn't displayed correctly.
                                Kind regards,
                                makemeasandwich
