SNMP Builder for Zabbix
  • aaresmi
    • Aug 2015
    • 18
    #496
    Yes of course.
    • aaresmi
      • Aug 2015
      • 18
      #497
      Hi spaww,
      I sent you a PM but dont know if You saw it,
      Finally I installed all ZE 2.1 pluggins (to test the script) and seems to ends OK but in zabbix console I have the next errors
      SQL error [ORA-00942: table or view does not exist] in [SELECT userid, tx_option, tx_value from zbxe_preferences zpre WHERE userid in (0,1) and st_ativo = 1 order by userid, tx_option]
      oci_fetch_assoc(): ORA-24374: define not done before fetch or execute and fetch [dashboard.php:22 → require_once() → require_once() → DBfetch() → oci_fetch_assoc() in /home/swcomun/herrtux/aaresmi/mon-zabbix/httpd/htdocs/zabbix/include/db.inc.php:600]
      Undefined index: map_company [dashboard.php:22 → require_once() → require_once() in /home/swcomun/herrtux/aaresmi/mon-zabbix/httpd/htdocs/zabbix/include/zbxe_visual_imp.php:236]
      Undefined index: url [dashboard.php:31 → require_once() → zbx_construct_menu() in /home/swcomun/herrtux/aaresmi/mon-zabbix/httpd/htdocs/zabbix/include/menu.inc.php:338]
      Undefined index: url [dashboard.php:31 → require_once() → zbx_construct_menu() in /home/swcomun/herrtux/aaresmi/mon-zabbix/httpd/htdocs/zabbix/include/menu.inc.php:342]
      Undefined offset: 0 [dashboard.php:31 → require_once() → zbx_construct_menu() in /home/swcomun/herrtux/aaresmi/mon-zabbix/httpd/htdocs/zabbix/include/menu.inc.php:373]
      Could you guide, please?
      Regards
      • sire
        • Jul 2010
        • 210
        #498
        SNMP Builder for Zabbix 2.4.7
        Hi Guys,
        I have updated SNMP Builder to work with Zabbix 2.4.7. Please download from https://github.com/macrokernel/zabbi...der/tree/2.4.7. Installation instructions are also there.
        It works on my Debian-based Linux with Apache 2.2.22, PHP 5.4.4, Net-SNMP 5.4.3.
        Thanks to Lizard, whitevv, KakersUK and dionnes for patch ideas.
        Regards,
        Sergey Syreskin
        Monitored hosts: 2646 / Active items: 23604 / Server performance: 765.74
        Temporary out of Zabbix business
        • dan_cytexone
          • Dec 2008
          • 61
          #499
          Have you tested with 3.0?
          • sire
            • Jul 2010
            • 210
            #500
            No, I don't have 3.0 installed. Almost sure that SNMP Builder will not work with 3.0.
            Regards,
            Sergey Syreskin
            • dan_cytexone
              • Dec 2008
              • 61
              #501
              Originally posted by sire
              Hi Guys,
              Thanks for this! I tried to install it and I can't seem to get it to work. Here is what the screen looks like.
              No matter what MIB I try it only shows up with iso / ccitt underneath it and nothing works. I can snmpwalk and snmpget the device from the console. the import mib also doesn't work, but I manually uploaded the MIB to the server.
              • sire
                • Jul 2010
                • 210
                #502
                Hi, have your tried more basic MIBs like IF-MIB or HOST-RESOURCES-MIB?
                Regards,
                Sergey Syreskin
                • dan_cytexone
                  • Dec 2008
                  • 61
                  #503
                  I was able to get this working by adding the main MIB directory into the snmpbuilder.php file. It was looking for those core MIBS.
                  Took me a while, noticed the errors primarily in Apache / error.log
                  • Aksel
                    • Aug 2014
                    • 101
                    #504
                    Good evening.
                    Somebody set this script on 3.0?
                    • Gleb
                      • Apr 2016
                      Hi!
                      I have some problems with Zabbix appliance 2.4 (open suse) and SNMP Builder. I have installed SNMP Builder, and i can see it in Zabbix Configuration menu. But, when i try to select mib in drop-down list, i see
                      PHP Code:
                      Fatal error: Call to undefined function json_encode() in /usr/share/zabbix/snmp_builder.php on line 700
                      SNMP Builder installation log:
                      linux-yd68:/usr/share/zabbix # patch -p3 < snmpbuilder-2.4.7.patch
                      patching file include/menu.inc.php
                      patching file include/page_header.php
                      patching file include/views/administration.snmp_builder.php
                      patching file js/jquery/jquery.cookie.js
                      patching file js/jquery/jquery.jstree.js
                      patching file js/jquery/themes/mib/style.css
                      patching file js/snmp_builder/DynTable.js
                      patching file js/snmp_builder/snmp_builder.js
                      patching file jsLoader.php
                      patching file snmp_builder.php
                      linux-yd68:/usr/share/zabbix # unzip zabbix-2.0-snmpbuilder-imgs.zip
                      Archive:  zabbix-2.0-snmpbuilder-imgs.zip
                       extracting: js/jquery/themes/mib/d.gif
                       extracting: js/jquery/themes/mib/d.png
                        inflating: js/jquery/themes/mib/dot_for_ie.gif
                        inflating: js/jquery/themes/mib/globe.gif
                        inflating: js/jquery/themes/mib/table.gif
                        inflating: js/jquery/themes/mib/throbber.gif
                      May be someone can give advice?
                      • richlv
                        • Oct 2005
                        • 3112
                        #506
                        Originally posted by Gleb
                        Hi!
                        PHP Code:
                        you might be missing php json support. try this :
                        zypper in php5-json
                        rcapache2 restart
                        • Gleb
                          • Apr 2016
                          zypper in php5-json
                          rcapache2 restart
                          Thank you! It helped!
                          • spaww
                            • May 2009
                            • 178
                            #508
                            For automatic install... i need to change the SNMP-Builder to use some functions included on Zabbix-Extras, so install "my build" of SNMP-Builder without the ZE... is very more complicated...
                            Currently I are coding a new version of ZE and SNMP-Builder for Zabbix 3 ... but have a LOOOOT of things to change to SNMP-Builder works on him...
                            Originally posted by aaresmi
                            Sorry spaww, one question. I am trying to install only the SNMP Builder plugin from zabbix-extras 2.1 manually,
                            For it, I did:
                            0.- uncompress snmpbuilder-master.zip
                            1.- copy the content of snmpbuilder-master folder into my zabbix web root
                            2.- Include the refer to zbxe-snmp-builder.php in include/menu.inc.php
                            When i click in SNMP Builder label i get Fatal error: require_once(): Failed opening required 'include/zbxe_visual_imp.php
                            I try to search this file in the plugin but i didn't find it.
                            am I doing something wrong?where can i find it?
                            Thanks a lot for your help!!!!
                            Adail Horst
                            OCA/OCP - Oracle Application Server
                            ZABBIX Certified Specialist
                            http://www.spinola.net.br/blog (Blog sobre Zabbix e tecnologia)
                            • richlv
                              • Oct 2005
                              • 3112
                              #509
                              heya - poke me on irc, let's try again to expose the extras to the english speaking community more
                              • gelowe
                                • Jun 2008
                                • 30
                                #510
                                zabbix 3
                                Does this work with zabbix 3.0? If not is anyone looking to update it so it will? seems like too good of a tool to not get added to the overall zabbix development.
