Proxy talking to server problem
  • Wokwon
    • Jul 2009
    • 9
    I have a Zabbix 1.6.5 server at my office which is monitoring the infrastructure correctly.
    At another site I have deployed a Zabbix 1.6.5 proxy server.
    The proxy shows up in the console (Configuration -> Hosts -> Proxies) as last seen some time ago and every now and then the time goes to zero so I assume the server can at least communicate with the proxy.
    The proxy log continually reports:
     Unable connect to the server [server]:10051 [Cannot connect to [server:10051] [Interrupted system call]]
    I can telnet to the server from the proxy on port 10051 successfully (i get a blank telnet window so I assume that this is OK)
    The agents that report to the proxy never end up with any data on the server (the items for those agents all show "-")
    The proxy log also shows:
     Error while receiving answer from server [ZBX_TCP_READ() failed [Interrupted system call]]
    --and--
     Heartbeat message failed
    I am at a loss of what to check next.
  • richlv
    • Oct 2005
    • 3112
    just for some possible cause elimination, can you try active agent items on that host ?
    do you see any errors in the server log as well ?
    • pedmond
      • Sep 2009
      Hi Richlv,
      I've got the same problem on a 1.8.2 revision 9779. Would you have a solution ?
      Thank you !
      Pedmond
      • syntaxcollector
        • Nov 2008
        I have the exact same problem. Has anyone figured this out yet?
        • tof233
          • Nov 2010
          • 94
          Hello everybody,
          I have a problem setting up the proxy with zabbix 1.8 :
          I installed a proxy on a server 192.168.10.27 .
          It should connect to zabbix_server 192.168.10.26 .
          On the zabbix_server log file I got,
          Autoregistration data from active proxy on [::ffff:192.168.10.27] failed: proxy [svimocavl007] not found
          On the zabbix_log, I got :
          8745:20101126:113422.238 In send_heartbeat()
           28745:20101126:113422.238 In connect_to_server() [192.168.10.26]:10051 [timeout:60]
           28745:20101126:113422.239 In put_data_to_server() datalen:55
           28745:20101126:113422.239 In send_data_to_server() [{
                  "request":"proxy heartbeat",
                  "host":"svimocavl007"}]
           28745:20101126:113422.239 In zbx_recv_response()
           28745:20101126:113422.241 zbx_recv_response() ''
           28745:20101126:113422.241 End of zbx_recv_response():FAIL
           28745:20101126:113422.241 End of put_data_to_server():FAIL
           28745:20101126:113422.241 Heartbeat message failed
          I don't understand why the server says: "proxy [svimocavl007] not found". I didn't find a place on the server web interface to register the proxy. So I assume it should be auto registrated by the zabbix_server.
          • richlv
            • Oct 2005
            • 3112
            administration -> dm -> proxies
            • tof233
              • Nov 2010
              • 94
              Thank you richlv but it says :
              Your setup is not configured for distributed monitoring
              Edit ->
              Oops, it's in the documentation: http://www.zabbix.com/documentation/...ted_monitoring
              Thank you
              • richlv
                • Oct 2005
                • 3112
                no - see the dropdown in the upper right corner, it should have an option "proxies"
                • tof233
                  • Nov 2010
                  • 94
                  You're right
                  {"response":"success"}
                  Youpie!!!
                  Thanks to you a new Zabbix heart just started beating
