Cannot make graphs in 1.8.3
  • TerryDawson
    • Sep 2010
    I've been playing with a brand new Zabbix 1.8.3 installation.
    Everything seems to be working well, except for custom graphs.
    If I look under Monitoring->Latest data->(Item->Graph) I get the simple standard graph that I expect.
    I've tried associated graphs directly with hosts, graphs with templates and that template with a host, that template with a group. No matter what I do, Monitoring->Graphs is empty.
    I see nothing unusual in the zabbix-server log.
    I'm now presuming that either I'm doing something stupid, or there is a bug.
    Is anyone else experiencing this problem? Can anyone suggest what I might be doing wrong?
    regards
    Terry
  • TerryDawson
    • Sep 2010
    Followup: Cannot make custom graphs in 1.8.3
    A relevant follow-up to my own posting.
    It turns out that adding the graphs I've already created to a screen works just fine.
    They still do not show up in Monitoring->Graphs.
    Bug?
    • TerryDawson
      • Sep 2010
      Hmm..
      Ok, I've made graphs work, mostly ..
      It turns out that Zabbix isn't behaving the way I expected in the Monitoring->Graphs page.
      I expected that if I had 'Graph' set to 'all' that all graphs matching the specification of 'Group'/'Host' would be displayed, ie if I selected a single host I expected that all graphs for that host would be displayed. This turns out not to be the case. I can only select and display a single graph at a time in Monitoring->Graphs page.
      Is this by design? Or should 'Graph'=='all' show all matching graphs?
      • Aly
        ZABBIX developer
        • May 2007
        • 1126
        This is by design, but will be improved in near future (ZABBIX 2.0)
        Zabbix | ex GUI developer
        • shanewipe
          • Jan 2011
          it seems good and I hope you will keep up the good work in future as well
          • bricklayer
            • Jan 2011
            I thought I was having a problem when I created a custom graph in a template but all I was seeing was an empty graph that said "no data".
            But as you pointed out, you have to select a specific graph under Monitoring -> Graphs to see the plotted data.
