no communication between server - agent,
  • mr_jack
    • Aug 2012
    Hi guys,
    I've compiled zabbix 2.01 on an 12.04 Ubuntu box. Which runs okay, the server connects to the locally installed agent.
    But it fails to connect to an agent running on a windows box ( on a different network ). The 'Z' does not go green.
    The frontend doesn't specify an error, nor does the server.log.
    When I do a tshark trace to the client I see my manually generated traffic going to the host.
    An zabbix_get to the agent for ping or version gets an reply back from the agent and if I check the agents logs I see these request coming in.
    But it fails from the zabbix server / frontend.
    Does anybody have some hints, ideas to get this fixed ?
    Thank you for your time,
    Cheers,
  • mr_jack
    • Aug 2012
    Okay,
    So I decided to take another coffee, and had a fresh look at the problem.
    I had source ip in the server.conf on 127.0.0.1 , changed it to the network ip and than it started working.
    Again thank you for your time, my apologies for not looking better.
    Cheers,
