No data display on dashboard
  • Speeder2
    • Aug 2018
Name:	no data_dash.JPG
ID:	364571Click image for larger version
    I am new user of Zabbix system . I already install version 3.4 on Debian 9.5. Everything is fine, ( i already monitor 10 Windows serwers) except graps on dashboard which i try display. I try displays both, graps from templates and graps creating myself directly from items and no luck. When i switch to Monitoring- graphs - everything is fine - all data are displayed correctly. I use passive mode for agent. Please give me some advice , i try google problem but i didn't find solution for my issue.
    Below I attached pictute which describe my issue... First screen is from dashboard display, second from Monitoring-Graph
  • Danethz
    • Aug 2018
    • 18
    Hello!
    Same promlem.
    Ubuntu 18.04.1 LTS
    zabbix_server (Zabbix) 3.4.12
    Revision 83229 30 July 2018, compilation time: Jul 30 2018 11:36:38
    There is "no data" on dashboard graphs, but a can see the data on graph itself and in item's "Latest data".
    No matter what item\graphs selected - "no data".
    Reconfigure\delete widged gives no help.
    • dimir
      Zabbix developer
      • Apr 2011
      • 1080
      In the dashboard you also have a timeline, on top-right. Are you sure the period there is the same as in "Monitoring -> Latest data"?
      • Danethz
        • Aug 2018
        • 18
        Thx for reply
        Yes, in both - 1 min.
        • dimir
          Zabbix developer
          • Apr 2011
          • 1080
          Looks like different graphs, simple graph is "Memory usage" and dashboard has "Free" and "Total" memory.
          • lvan_law
            • May 2019
            • 10
            Mark, I have the same problem with you and I'm seeking for the answer.
            • lvan_law
              • May 2019
              • 10
              Hi Speeder2,
              Have you resolved your problem, do you have any solution? I have the same problem with you.
              • proczniak
                • Nov 2017
                Originally posted by lvan_law
                Hi Speeder2,
                SOLUTION:
                On the dashboard click "Filter", adjust your time scope. Voila!
                • caapdacced
                  • Jan 2021
                  Same problem on Ubuntu 20.04
                  I'm using zabbix-agent and zabbix-server (ver. 5.2.3)
                  "vm.memory.size" didn't have any output
                  • jeeva
                    • May 2021
                    I have the same problem.
                    Zabbix 5 LTS with nginx
                    Zabbix 5.0.9.
                    https://prnt.sc/12smxvz - The dashboard shows now graphs, however graphing shows under latest data for the zabbix server, https://prnt.sc/12smz3n
                    I also haven't had a single alert/problem raised on the global view dashboard - https://prnt.sc/12sn07u, even if i switch off switches etc,
                    In my previous iteration of zabbix (zabbix 5 LTS + apache) it will alert even if i pull out a network cable.
