Fresh Install Server not running Error
  • bdoubleu
    • Sep 2018
    Hi all,
    I have a clean install on Ubuntu Bionic Beaver and I am not able to get the server running.
    Web interface shows:
    Zabbix server is running NO localhost:10051
    When I restart from command line, I get :
    Job for zabbix-server.service failed because the control process exited with error code.
    See "systemctl status zabbix-server.service" and "journalctl -xe" for details.
    I read the post about SELinux, but does that pertain to this version?
    I just want to get this up and running as a POC.
    Thanks!
  • bdoubleu
    • Sep 2018
    Is there a vmware preconfigured image anywhere that can be used for testing?
    • dimir
      Zabbix developer
      • Apr 2011
      • 1080
      Sure, we've got VMware and other appliances:
      Download and install the pre-compiled Zabbix appliance.
      or, if you wish, docker images:
      Official Zabbix Dockerfiles. Contribute to zabbix/zabbix-docker development by creating an account on GitHub.
      • bdoubleu
        • Sep 2018
        awesome. I will try both. thanks... the docker image says not ready for production, but I assume it functions well enough for a POC?
        • dimir
          Zabbix developer
          • Apr 2011
          • 1080
          Sure. I have pointed you to the latest version, pre-4.0 . If you like, you can try 3.4
          GitHub is where people build software. More than 225 million people use GitHub to discover, fork, and contribute to over 800 million projects.
          The reason is, 4.0 will be LTS, while 3.4 is not. So, for near future deployment I'd recommend pre-4.0.
          If you'd like to hear what Zabbix users say about it, consider https://www.zabbix.com/zabbix_summit2018 that will happen very soon. :-)
